12lbs of boost = 1400HP?
Results 1 to 14 of 30
    273.36 Miles from Havasu
    Thumbs up 12lbs of boost = 1400HP?
    Perhaps I'm gay...
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    NIIIIIICEEEEEE ........ More boost , more roost
    [/SIGPIC]
    spokane, WA
    With the right set up a 582 could make 1400 @ 12psi..... American turbine said my 496 at 16psi was making 1300+ to spin my impeller where I was in a jet..
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    i'm back!! 1QuickCP's Avatar
    Montana
    would hope it would, but dynos are nothing but a tuning tool, the proof of the power is in the running. Figure most every 540-575 I ever built with decent cam ect made around 1000-1050 @ 10 lbs..raw,uncorrected hp...corrected it can be anything you want....
    spokane, WA
    Quote Originally Posted by 1QuickCP View Post
    Couldnt have said it better Bill!!!
    Travis
    Thumbs up
    I believe Pyburn's Chief engines pushed his Skater to 185MPH on pump gas. I think it's great what these guys are doing with big HP/lower boost motors- hats off to them.
    You guys crack me up....your junk is great, but anyone elses is suspect.
    What grade are you guys in anyway?
    Perhaps I'm gay...
    Montana
    Yup everyones shit is suspect, you tend to get that way from owning a race engine shop for 25 years.....lol.....
    Oh, I have a MS in mech eng btw, im not in school any longer, and if you yourself did not suspect the dyno number, WTF are you doing posting a question mark after it in the thread title???? So going on the information you posted in the title of your thread, you are in fact asking if it is possible for a motor at 12 psi to make 1400 hp, ( 12psi = 1400 hp ?) and both of us replied that yes it is possible to do just that. And that I have built a few 580ish motors that pull 1000 uncorrected and thats around 1300-1400 corrected. So now that we both have said it can be done, you decide to post negative...sorry I just can't understand your reasoning.
    spokane, WA
    Quote Originally Posted by Havasu Hangin' View Post
    You posted the thread with a question mark at the end of it as if you didnt believe the numbers yourself.... All I did was reply that it could make that power at that boost level if done right....
    Travis
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    ...both of us replied that yes it is possible to do just that. And that I have built a few 580ish motors that pull 1000 uncorrected
    Well, I apologize if I offended you. The way I took (paraphrase) the above quotes, "Yes, it can be done- even I can do it with a happy dyno (cheat)."
    The reason for my question mark is to see if any of you guys have seen 93 octane blower motors making that kind of power. Not turbo...and they actually have to have some manners to be shiftable.
    Perhaps I'm gay...
    Montana
    Its all good.....
    Ada, Michigan
    So going on the information you posted in the title of your thread, you are in fact asking if it is possible for a motor at 12 psi to make 1400 hp, ( 12psi = 1400 hp ?) and both of us replied that yes it is possible to do just that. And that I have built a few 580ish motors that pull 1000 uncorrected and thats around 1300-1400 corrected. So now that we both have said it can be done, you decide to post negative...sorry I just can't understand your reasoning.[/COLOR]
    I can see the 12 # boost making 1400 hp if the static compression is high enough. That's not going to happen with 8:1 compression though.
    I reviewed the dyno sheet on my engine and the corrected torque was within 25 ft lbs of the observed peak at 4800 rpm. The hp was within about the same 25 - 30 hp at the peak hp 5800 rpm.
    If the corrected was 300 - 400 hp off from the observed the dyno operator should be fired.
    okie, lake Texoma
    I reviewed the dyno sheet on my engine and the corrected torque was within 25 ft lbs of the observed at 4800 rpm. The hp was within about the same 25 - 30 hp at 5800 rpm.
    No kidding. The way I see it you should pay no mind to the corrected #'s. Unless your looking for something to boast about. We will not run our boats in a perfect world at sea level so who cares about corrected. The actuals are what counts.
    H8-2-W8
    [email protected] first pass
    Montana
    Yup, thats why I never ran corrected numbers on my dyno. As far as 300-400 off...lmao...I've seen sheets worst than that...ah the stories I could tell from shops people would be very suprised did it.
    Heres a example, motor tested at 5200 feet,100 deg,50 % hum, 29.05 pulls 1000, just puttin that in a common used formula to correct for sea level we get.....ta da......1297, its just that people are so hung up on this shit builders fudge there results for the stupid braggin number. The old question, how come your 1600 hp motor from a respected shop that cost 90k runs the same in your car as the 1200 hp motor you had that I dynoed ? ummmmmm
    Thumbs up
    So a 1300HP-1400HP blower motor on 93 octane is doable?
    Perhaps I'm gay...
