1300hp non intercooled 383 smallblock with a carb
Results 1 to 14 of 17
    okie, lake Texoma
    Default 1300hp non intercooled 383 smallblock with a carb
    this link shows the dyno charts
    http://www.theturboforums.com/smf/in...topic=140800.0
    and the vid
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    the thing probably made 1400+ hp if you figure in the parasitic loss of driving the supercharger.
    H8-2-W8
    Chico, Ca
    what the!!!... thats not a turbo!!
    that just tickles my fancy right there! F2 procharger at its best!
    okie, lake Texoma
    I know,lol. If I were to run a supercharger it would no doubt be a procharger. No positive displacement for me.
    But DAYUM!! those things are expensive when you get into the larger setups.
    Sure would be nice to get to run a bought set of headers instead of the custom made stuff with the turbs too.
    Bet this little small block would be a blast in a light cheyenne, esp if it were built with an aluminum block.
    H8-2-W8
    Chico, Ca
    I really wish they would have shown the low end torque these things make. just the fact this little engine maintaines 820 to 900 lbs/ft of torque from 5800 to 7700 is crazy. the whole "small blocks don't work with jets" mentality is no where near the truth when dealing with these things. I agree...this would be a super fun setup in a light boat.
    okie, lake Texoma
    looks like the F2 is $5045+ and the F3 is $6295+
    You can buy a hell of a set of turbos for less. Which is better? Who knows, but it would probably depend on the application.
    The turbo should make a little bit more hp at the same boost but the procharger will come on a little bit sooner.
    Still would be a substantial investment by the time you either put a blowthrough carb or an efi system on top of that price. THEN build an engine capable of withstanding the abuse.
    H8-2-W8
    I really wish they would have shown the low end torque these things make. .
    Alot less the a properly set up turbo deal. Problem with belt centrifs is, if your not spinning them, they aren't making boost. At least with a turbo, regaurdless of the RPM, you can make tons of exhaust heat. Nothing can touch a turbo in the highly loaded low RPM department. Not even a roots. But why would you care about low end in a jet. There is no such thing as a jet climbing a hill, towing a trailer full of horses
    Ada, Michigan
    looks like the F2 is $5045+ and the F3 is $6295+.
    Wow, And I thought I was extravagant spending $ 1500. on two turbo's.
    Chico, Ca
    Yeah screw that!! not even I would buy one for that price! definitely would have gone turbo had I not gotten a smokin deal on my setup.
    Chico, Ca
    I've never said anything bad about turbos...i love them. I also love prochargers...roots....well, we will call roots the red headed step child. No doubt i'm not going up hill, but i do have one massive impeller to spin, and being able to spit out all that torque at lower speeds in the 4000+ is critical. wouldn't want to get stuck not being able to use your engine in its peak power because you can't get it even close to the needed rpm because of the lack of torque down low. Obviously not exactly common for any boosted application, but most people don't realize the crazy flat torque curve these things create, and thats the main thing. just spreadin the procharger word
    spokane, WA
    Those sound like complete kit prices with everything to bolt on, not just a single head unit.....
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    Didn't mean to imply that you were thrashing turbos. Just saying people seem to think the you have to get the motor up and spinning to get a turbo on line. Nothing could be further from the truth. A turbo could care less about the RPM of the motor. It just whats it loaded. WOT at 1500 Rs, up against a full load, look out. You better have one damn good crank in that thing. Even a roots would be hard pressed to make the low end of a fully loaded turbo at low Rs. Problem with a boat is, you could never hope to load a turbo that hard at that low of a RPM. I would'nt give a dime and a half for a belt centrif in a car, because they don't make shit for boost at 2500. And thats when I want it, in a land locked vehicle
    okie, lake Texoma
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    It is kit price. If you were going to run one you would probably need more than just the head unit.
    H8-2-W8
    okie, lake Texoma
    Do you think that torque makes no difference in a jet ? Thats its entirely about hp ?
    H8-2-W8
