stacking headgaskets
Results 1 to 14 of 38
    Senior Member lbhsbz's Avatar
    Long Beach
    Default stacking headgaskets
    My machine shop said that since the block has already been decked...and it's a little on the low side (about 0.005 outta the hole he said) decided to not deck it. While I was in the process of doing my cleaning and pre-assembly measurments I discovered that the deck is way to rough from a previous resurfacing to even dream of sealing against a head gasket...looks more like the surface of a file. It'll take about .007 or .008 to clean up, which will leave me about .013 or so out of the hole using calculated numbers. Actual measurements and rocking the piston in the bore yeilds about .0015-18 out of the hole.
    With a .041 gasket, the quench is around .023"...which won't fly. With an .051 MLS gasket, this will set the quench at around .033 or so, which is a still a bit tight.
    I was kicking around the idea of grabbing a 3rd gasket and using layers off of it to make a total thickness that would get my quench to .040 or slightly more.
    This seems halfway hack to me though. What says the PB brain trust?
    Option 2 is to find yet another block.
    Option 3 might be to use a thicker copper head gasket,, or get Cometix to make up whatever thickness head gaskets you want to give you proper quench.
    Long Beach
    I guess I'm asking if making up this distance using the headgasket is a good idea. I generally like to keep gaskets as thin as possible because the more surface area exposed to the chamber, the bigger the beating the gasket takes. I'm not opposed to getting another block if theres any question as to the integrity of running a .060" head gasket vs a .041 head gasket. I've always run the .041s so I don't know.
    Senior Member Blown to the Bone's Avatar
    chino ca
    you could machine the deck of the pistons !
    Nov 2008
    Orangevale CA
    I have run a.060 copper head gasket ( with o-rings ) on a496cid blown alky motor at 17 psi of boost No problems, ...........E
    Long Beach
    Ok, I'm not O-ringed.
    Can someone please give me the copper vs MLS lesson now?
    Sapulpa Okla
    I like copper. Just silicone around all water ports. Ive seen too many mls failures at around 20 psi boost. Don't know why they became so popular .You can run copper without o-rings up to about 20 psi that's just what Ive done hope this helps Titan makes one with a o-ring inside the copper don't trust the print-o seal use silicone on the water ports.
    Whitewright, TX
    Quote Originally Posted by pisston in the wind View Post
    Yep, what he said. I've had good luck with the SCE ICS copper head gaskets on my blown deal, with or without block o-rings. They make a .041, .050, .062, .072 and even a .080 thick gasket. Jocko
    http://www.scegaskets.com/Chevrolet/396-454-Mk-4-Big-Block/ICS-Titan-Head-Gaskets/ICS-Titan-Head-Gaskets-p6631756.html
    Senior Member Bruise Brothers Dad's Avatar
    Pomona,Ca
    Quote Originally Posted by Blown to the Bone View Post
    Since our buddy Phill moved back to New Zealand finding a good machinist is getting harder......Sparks
    Need help finding this 1973 Sanger 18'6" bubble deck mahogany bottom and stringers I was living in Pomona when I sold her in 1979. Just wonder if she still exists
    Update Found my old Sanger 12/7/14 in Reno.
    Long Beach
    I'd rather not.
    Pat maybe give these folks (Cometic) a try like Barry suggested , great product and super people to deal with Tom
    http://www.cometic.com/
    Mar 2010
    grand lake ok
    i run sce titan copper gaskets at .080 due to my domes and have never had a problem one
    Somewhere between Paso & L.A.
    I did a motor for a guy awhile back that the pistons were out of the deck
    around 32 thousands, used a cometic that was 72thou . it's still running
    very well for the guy, although he's only running around 7 or 8 lbs. boost.
    don't see a problem doing the same in your deal(altho they ain't cheap,
    'bout 160.00 each)
    Morgan Hill
    I would not "layer" gaskets, but have no problem with a copper or Cometic gaskets...
    Layering would be asking for trouble doubling your chances for a catastrophic failure IMO...
    GT
