Intake manifold torqe specs w/ aluminum heads
Results 1 to 8 of 8
    Las Vegas, Nv
    Default Intake manifold torqe specs w/ aluminum heads
    Does any one know what the intake manifold should be torqed to on a set of aluminum heads?
    If it matters, the heads are AFR 305's and the manifold is an edelbrock victor ram TR. The bolts are not arp, but ss socket cap bolts....Thanks...Hal
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    My book doesnt list a seperate torque spec for aluminum vs iron for head bolts. It does however for spark plugs, so that makes me think it's the same for iron and aluminum. personally, i'd wait till tomorrow and call the head and bolt manufature and see what they say.
    Las Vegas, Nv
    I found a site that listed the spec as 25' lbs for cast iorn heads,but said nothing of Aluminum.
    San Clemente, Ca
    ah crap, i for some reason though you where looking for head bolt specs. I just checked again and my book still only lists one spec for intake manifold (25 lbs the same as what you found).
    Also, this site shows 25lbs for aluminum engines.
    http://torquespecs.tripod.com/hi_po_chev.htm
    torque specs are the same for iron or alumn heads. It the manifold your torquing. make sure you use some anti-sieze. Bolts in alumn have a nasty habit of giving false torque values.
    I just tighten the f--k out of them. never broke one or striped one---yet!!!
    Same method you use for rod bolts?
    Nope------but funny
