Heres a question for you guru's
Results 1 to 14 of 25
    okie, lake Texoma
    Default Heres a question for you guru's
    When in the torque sequence do you torque the head bolts that go from under the intake on an aftermarket block ?
    Then next ? how the hell do you get a torque wrench on'em ? What do they torque to on a brodix alum. block ?
    Thanks Hass
    H8-2-W8
    [email protected] first pass
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You get a crow's foot on it and recalculate the torque.
    Use the torque value for the fastener. Prolly ARP small diameter head bolt or stud with washer and small diameter nut. If so call them.
    T1 x L1
    --------- =T2
    L2
    T1 is the original torque
    L1 is the length of the torque wrench from the center of the handle to the square drive
    L2 is the torque wrench length with the crow's foot
    T2 is the new torque. It will be a little less.
    QE 439 Twin Turbo
    Arroyo Grande
    T1 x L1
    --------- =T2
    L2
    36 to 40 lbs....
    i'm back!! 1QuickCP's Avatar
    Montana
    i use 12 pt nuts and a small 3/8 drive torque wrench with a cut down socket....or a box end wrench if theres no way at all to get it...you would be amazed how close ya can get. clamp a stud in vise, slip a aluminium tube on it, washer,moly 12 pt nut..practice with that get a good feel for 65 ftlbs or whatever...I can get within 5 lbs every time, and within 2 most of the time... you can also just cut down the box wrench handle and give it all you got with 1 hand, measure torque, re cut..measure ect.. you can get the wrench to a length that all you can pull with one hand is 65 . Or like my friend with the KB hemi..just pulls it as hard as he can and could care less...car runs low 6's so I shut up....
    okie, lake Texoma
    Quote Originally Posted by 1QuickCP View Post
    This is a Brodix aluminum block and Brodix heads , it has the black socket heads for an allen tool. My old engine had the same fasteners and i always just tightened the sh-t out of them and had no problems, just wondered how everyone else does it.
    My father said i could probably strip the SOB out with a 2" long allen tool
    I like to go as far as it will go +1/2 turn,lol.
    H8-2-W8
    Rookie. You tighten it till it strips or snaps. Then back it off a 1/2 turn.
    okie, lake Texoma
    I'll write that down so as to remember it
    H8-2-W8
    Yea, I've wondered about that too... My vise grips don't have a torque read out
    waterloo
    I have a Mac crowsfoot box end deal that goes on the torque wrench. If the tool is 90 degrees to the wrench you do not need to compensate for it.
    Wags
    Even though it makes the wrench longer???
    Done alot of aircraft work have ya?
    Technicalities, technicalities
    S CP
    waterloo
    Uh, it does not make the wrench longer. It would make the wrench longer if the crows foot was straight out. It if is 90 deg. to the wrench the theoretical length is not changing.
    Duh.
    Wags
    Duh.
    Wags
    Of course it is, wags. Think of it this way...if the crow's foot was 12" long, would that change the leverage?
    Unless what you're turning is at the center of that square drive on that torque wrench, the value will be different, and you should compensate.
    Senior Member lbhsbz's Avatar
    Long Beach
    Duh.
    Wags
    Correct. the effective lenght is the length between the end of the handle and center of the nut onto which the wrench is installed. At a 90° one way or another, the length doesn't change.
