Gotta a Carb question
Results 1 to 11 of 11
    Mar 2010
    Clarksville, TN
    Default Gotta a Carb question
    Hey guys, I got a carb/fuel question for ya .. I took my bowels off last night to change my primary jets and noticed a white residue in my bowels .. The boat has been setting for about a month and the bowels were dry.. I'm runnin AV gas with a shot of marvels in it.. I was just wondering what would cause this residue and would it hurt anything goin through the carbs .. Thanks
    Senior Member lbhsbz's Avatar
    Long Beach
    If you've got white shit in your bowels, go see a doctor.
    White shit in your bowls is a different story. I pulled my carbs apart about 2 weeks after sinking my boat and the river water had started to eat the aluminum/pot metal that the carb is made of....looked like it was full of white tooth paste.
    You've got some moisture/water that is getting into the bowls and spending an extended length of time in there. Figure out why.
    Senior Member norcal73's Avatar
    Lake County, Ca
    Sounds like water has found its way and stayed. We use to drain the water content out of planes via a petcock valve under the fuel tanks before take-off. Always had a little water.
    norcal73
    Mar 2010
    Clarksville, TN
    LOL I ment bowls !!!! I cant spell worth a shit either but thanks
    987 is offline
    SWDBA 987's Avatar
    Aug 2010
    Rio Rancho, NM
    The white residue is from your av gas, av gas has a little antifreeze in it to prevent freezing at high altitudes, doesn't hurt anything
    96' 18ft Pantera Drag Boat
    Quote Originally Posted by 987 View Post
    Very correct that AV gas has an ethylene-glycol additive for not freezing in the thin cold air. BUT many (including myself] have seen the same thing without running AV gas! It is caused by condensation and electrolysis in the carbs. Hot motor mixed with a cold feul in a captive area will sweat and then toss in electrolysis with a battery still hooked up and bingo----cum stains in your'e BOWELS
    Mar 2010
    Clarksville, TN
    Now that a good way to put it Ol Guy .. When I pull it out I alway unhook the battery
    Sep 2008
    OC, CA
    You guys crack me up with the BOWEL comments. Good thing to remember, unhook battery after using the boat.
    Massachusetts
    Kids at the MJ Neverland ranch were having the same problem.
    Real Boats Don't Have Propellers!
    -- Rivernut
    Thats a good thing! Now think of an ungrounded boat as you are wiping it down (static electricity) Then remember the hot motor cold feul syndrome. Its common in boats, just alot of guys dont get into the carbs as much and alot of times it gets washed away before being noticed. It really wont create alot of problems untill the mind-flock it thows in when you first see it! IMO
    Quote Originally Posted by Rivernut View Post
    Okay, now that is just sick
