454 big block chevy.. water temps and oil temps?
Results 1 to 5 of 5
    Senior Member norcal73's Avatar
    Lake County, Ca
    Default 454 big block chevy.. water temps and oil temps?
    What is the best water and oil temp while running a boat? I have a 73 Sanger V-drive with a 454 running between 5 and 7 boost through a 6-71. Timing lockout at 30 on the dizzy. Water temp at the intake was 120 degrees and oil at 220 degrees in the pan running straight 30 oil during break-in.
    norcal73
    I am going to assume this was at a cruise. If so, it could be a little warmer, but I would say its fine as is. It will probably climb some when hammered. If you want to raise the water temp, just restrict the over board dump from the engine a little. Oil temp is fine.
    Lake County, Ca
    Between 2000 and 2800 rpms for 30 minutes, yeah, basically a cruise. Would a gate valve on the water exit hose work? This lake is around 50 degrees in the spring and 88 in the summer.
    norcal73
    Lake County, Ca
    Correction
    Quote Originally Posted by norcal73 View Post
    Between 2000 and 2800 rpms for 30 minutes, yeah, basically a cruise. Would a gate valve on the water exit hose work? This lake ( Lake water temperature) is around 50 degrees in the spring and 88 in the summer.
    norcal73
    Yes you couild use a gate valve if you cruise it for long periods. But remember, the temp is going to jump when you hammer it. Specially a blown deal.
