pre dynoed motor
Results 1 to 14 of 17
pre dynoed motor
    Default pre dynoed motor
    Trying to get a reasonable baseline of how much a naturally aspraited 13.1 540c.i single dominator motor; fully cnc'd 325 darts w/ matched sniper intake. will make. Cam is a flat tappet (for now....).valve lift is .720. [email protected] 50 is 284* on a 108 lobe ctr. I know a mechanical roller would be superior; Just a ski motor deal. If...... and i say possibly if this combination makes 1.5 h.p per c.i i will be pleased. Would'nt mind hearing some of your opinions.
    Thanks Bryan
    Do you know the air flow of the heads ? With those #'s you can more than likely get within a few HP guess. ( +/- 10 hp) But off the top, your 1.5 HP # is probably close.
    Sleeper CP
    Big Inch Ford Lover
    13 to 1 skiboat
    Senior Member hotbo's Avatar
    lake Ouachita AR
    13 to 1 skiboat
    who cnced the heads.like sleeper said,hard to get real close without flow#s if you have them anyone can run it thru a program and get real close with the correct info,other than that you are really pissing in the wind imo.
    i have looked around but can not find #S for these heads and it will also depend on who cnced them.
    imo that is one hell of a large flat tappet cam profilegood luck,travis
    yeah tom 13.1 ski boat me like that
    Sleeper CP
    Big Inch Ford Lover
    368 cfm @ 28" of h20.
    Quote Originally Posted by mares98 View Post
    what lift?
    what lift?
    360 CFM x 2 = 720 ....
    360 x 2.1 = 756
    If you can make 2.1 HP per CFM you're doing pretty damn good. The flat tappet won't allow max flow under the curve but the 13:1 will give it some serious pop.
    My guess is, it will could make 740 Hp +/- 10 hp. More than likely 730 maybe 735. Just a wildass guess. But I think 1.5 HP/ cu. in is out with those flow #'s.
    Sleeper CP
    Newton Ks.
    From the guy who plays with DD way too much, 700HP.
    Way up at 6,500RPM or so.
    H.L. Mencken
    lake Ouachita AR
    i played with my dd to with some close flow#s i thought and came up with around 725 give or take.the flat tappet is killing it big time,imo.
    just like smokin said,6500 rpm
    but in the real world who really knows these programs do get close but not on the money.good luck
    Thanks for the replies, 750 or so sounds fairly reasonable with this cam cam profile.
    B1 Racing cs19's Avatar
    so where are you dynoing mares? while your there run the drag motor on the dyno.
    B1Racing.net
    Probablly westech, the dreaded drag motor . Im almost scared to.
    yes i know.
    B1Racing.net
