trim tabs for my daycruiser
Results 1 to 2 of 2
    Feb 2010
    Default trim tabs for my daycruiser
    picked up a used set of teflex co televator. they are used and did not come with a switch. just the hyd box, plated and rams and some hose. where can i find a wiring schematic and tepplate for how high to mount the ram from the plate etc. the plates are 12x18. i dont even know if they work so i want to bench test before i start drilling holes. and as for a switch....i can mock up a 3 position momentary for now if i have the wire diagrams
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Feb 2010
    no luck, noone has hydraulic that thaey can scan the original install manual on
