7.4 mpi question
Results 1 to 6 of 6
7.4 mpi question
    Junior Member 98Caliber1's Avatar
    Sep 2010
    Menifee, CA
    Default 7.4 mpi question
    Ok I have a 1998 Caliber1 21ft open bow with a mercruiser 7.4 mpi injected hp.
    What are some options I have to get some more power out of it? Right now it does 62-66mph and i just want to crack the 70 mph mark
    some suggestions?
    "Just Another Saturday"
    cfm
    cfm is offline
    Do you have the 385hp MPI ?
    Assuming (you know where assuming usually get's you) you are propped 100% on, you need a good dose of hp to reach your goal. If you want to stay FI then go to a shop like Tyler Crockett's where they have parts combos and their own EFI programming for those combo's.
    For a cheaper way, you can go carbureted and do the norm's - 750-800 Holley, Air Gap intake, camshaft replacement with appropriate hardware including springs, rocker arms, and etc, and exhaust.
    Sep 2010
    Menifee, CA
    there any benefits to staying fuel injected?
    cfm
    cfm is offline
    Remote start.
    Lost Wages, NV
    Personally I'd rather stay FI than go carb. I know there are several manufacturers that claim their headers pick up some power on those engines. A cam swap would help, but also require a retune or some way to tune the air/fuel ratio.
    Keith-
    Quote Originally Posted by 98Caliber1 View Post
    Only if you are leaving it stock.
