alpha one out drive
Results 1 to 13 of 13
alpha one out drive
    Jul 2009
    Default alpha one out drive
    does this out drive supply enough water to engine to keep it happy or does it need a water pump of some sort ? thanks for the help
    It supplies thousands of boats everyday. Mine works fine.
    El Monte
    The Alpha drive has an internal water pump that that supplies the engine with water. It needs periodic servicing (impeller replacement)
    B & D Marine Performance
    El Monte, Ca.
    Jul 2009
    so i can take the water pump off of the front of the engine ?
    Morgan Hill
    Quote Originally Posted by lowlow62 View Post
    Is that a real question?
    You can put a crossover tube on the engine an lose the engine mounted water pump, but it does not stop there....
    The engine mounted water pump does not pick water up from the lake, it circulates water through the block until the stat opens then it goes through the exhaust system to cool the manifolds and whatnot....
    You need to research it a lot more, but this requires some changes in the system as a whole...
    FWIW, I would rather see an engine mounted water pump before using the raw water pump to support the whole enchilada....The drive pumps are not all that impressive as far as flow. A Bravo type pump is a better choice IMHO....
    GT
    Green Bay Wi,USA
    make sure you know the engine coolant path. older engines are different. Did the water pump engine use a heat exchanger(water encapsulated radiator)? I have been following your project. Keep up the good work.
    Jul 2009
    I was just gonna run the cooling system just like on a jet boat kinda like the one on wasted wages lsx swap he is doing all i want to know is if the pump in the out drive will support the motor .... but i guess we'll find out this weekend as its almost done..... thanx for the help and input guys
    Morgan Hill
    IMHO, I would use the larger pump like on a Bravo deal....
    The drive pump is pretty wimpy in comparison.
    GT
    Jul 2009
    is that a direct replacement deal or do i have to modify the living crap out of it ?
    Morgan Hill
    Pretty easy swap depending on what engine...
    I have a complete pump assy. for a 454, they make one for the 350 as well (used on the Blue Water inboards among others)..
    You could pull the impeller from the outdrive and use the original water hoses, or install a thru-hull pick up and go the in board route..
    Both should do what you need...I don't have a lot of faith in the internal pump of the drive to be reliable for your particular application...
    GT
    Jul 2009
    ok put boat in water and could not get any water up in the engine. whats the deal supposedly it has a new water pump in the out drive
    El Monte
    ok put boat in water and could not get any water up in the engine. whats the deal SUPPOSEDLY it has a new water pump in the out drive
    El Monte, Ca.
    Morgan Hill
    Never assume, these impellers should be replaced annually.
    There are some things that can keep it from working, which drive? is the two halves through bolted or studded?, the through bolted ones are second generation and have a better water pump (read bigger)...
    GT
