600 chevy with 1071 blower
Results 1 to 14 of 20
    Senior Member Skydog's Avatar
    Jul 2010
    Default 600 chevy with 1071 blower
    About how many hours should i change valve springs? It is not a soild cam.
    Thank you
    I'm not sure if any of the performance guys in here would change quality valve springs based solely on an hour count.
    And more info would be needed from you to even begin to make an assumption I would think.
    S CP
    jus buy a 75buck on motor moroso spring tester and when they get outside each other or low, replace em i've had a set last 2yrs, and the next last 10hrs lol, ya never can tell these days
    I guess that would depend on the cam profile, average RPM they spend there time at, and who made them.
    Mild hydraulic, with isky tool room springs, running under 5000 Rs most of the time, propably live longer than you, but certainly longer than the motor or the boat.
    Aggressive hydraulic, with ProComp springs running 6800. Probably last a week.
    Yup, kinda what we do except I'll shim a spring if it's only a bit low. We dont' run really big cams with the blowers, but I still watch seat pressure pretty close. I usually replace only the intakes, then move the old intakes over to the exhaust and shim them up to where they need to be.
    Jul 2010
    Thank u guys keep talking i am soaking it up!!!
    Quote Originally Posted by Skydog View Post
    I see this is going to be like pulling teeth
    Cam type and lift & dur ?
    operatating rpm range typically ?
    Typical weekend use,, IE do you put 20 miles on it or 200 and how often?
    what springs are on it ?
    S CP
    Jul 2010
    Cam Lunati 663 680 114 4 custom hyd roller cam
    3000-4500RPM Rev limt 6
    Only used on the weekends and maybe run 20 miles a weekend that would be on the high side
    Lunati 1.550 dual hyd roller valve springs
    8 Manley 2.300 extream duty intake valves
    8 Feuece (sp??) 1.900 inconel exhasut valves
    16 Manley titanium valve retainers
    Hope that helps THANK YOU!!
    Matt
    Not sure the Lunati springs are top shelf, and for that application, I'd use the best springs you could afford. I'd be checking them at least once a season.
    Jul 2010
    10 4 What are the best i will get them.
    Thank you
    Thank you
    Need to know the installed height. Hyd roller springs are kind of in the middle between flat tappet and solid roller. The Isky tool room or PSI are good springs if they have something in that pressure range. You probably want something in the 200# closed, 500# open for what you're doing. The Isky 9915 might be a good one to look at.
    Need to know the installed height. Hyd roller springs are kind of in the middle between flat tappet and solid roller. The Isky tool room or PSI are good springs if they have something in that pressure range. .
    And should about last forever in that application I would think
    S CP
    Jul 2010
    Thank you guys! How will i find out what sping i need? And i bet this motor has 60 hours on them should i change them?
    THANK You Matt
    See post 3 above
    S CP
