Is there any info on these any where guys? Would like to see the guts of them. What oil to use? How to drain and fill it? I have a little oil leak on the back side. I am told there is only oil in the front and some grease on the gears on the back of the bolwer. It looks like the oil might be coming out where the blower meets the intake on the back side. If this is the case what is the easyest way to check this? Oil is getting pass the front seal back over the rotors and pushed out the back? If so is that front seal easy to change?
Thank you so much for any input!!!!hand
Matt
Matt
