CLosed cooling system
Results 1 to 5 of 5
    Senior Member Skydog's Avatar
    Jul 2010
    Default CLosed cooling system
    Is there any that will work and keep up with a 600 Meril 3 with about 950HP?
    Thank you
    There are ones that can keep up with 3 600 Merlin 3s. How much room you got? This ones tiny. Only 5" X 12" X 4" don't know off hand how many BTUs you need to move, but the last one of these I set, about a month ago, weighed 2000 lbs, and moved about 20,000,000 BTUs
    Ada, Michigan
    Quote Originally Posted by Skydog View Post
    Thank you
    I've seen some heat exchangers on marine diesels that would work.
    They're not real big.
    http://www.go2marine.com/productcenters/heatexchangers/
    Jul 2010
    Cool guys i am not sure how big i need? Any info on pluming them? I do have some room
    Thank you
    Pound for pound, inch for inch, these move more heat than any other exchagers out there. Its the same type cooler Keith Eickert uses for their bell housing mounted oil coolers. Look at the size of this thing, and the amount of heat it moves. And it will move a hell of alot more when the temperature of the cooling water is much cooler than the water hot water in the motor. I not sure this is quite big enough, but its close.
    LINK: heat exchanger
