oil cooler thermostat
    Default oil cooler thermostat
    what oil cooler thermostat do you like and why??
    thinking of using one of these with -12 fittings
    http://www.pegasusautoracing.com/pro...p?Product=1226
    The Pegasus unit is a decent piece. Be aware that just because it has -12 fittings, it is the same unit as their -10 piece. Only the body is machined for larger AN fittings. Same internals.
    The Earls has a little more "bling" but requires you to buy fittings. The ports are machined for o-ring AN fittings, You can buy radiused o-ring fittings that are radiused -10 for the stat side, and -12 on the hose side.
    LINK: oil thermostat
    Senior Member SFOcean's Avatar
    Feb 2009
    SF Bay Area
    I have used a few of these, they really work well and flow well too.
    Canton Racing - (the oil ports accept 1-1/16" -12 O-ring fittings)
    http://www.cantonracingproducts.com/...&category=2220
    Quote Originally Posted by SFOcean View Post
    I was trying to remember the other oil stat. This is it. The Canton is an excellent oil stat. A little big, but great flow, and easy to clean.
