peanut heads
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 103
peanut heads
    Cole SS cole ss's Avatar
    Rochester, wa.
    Default peanut heads
    Does anyone know the combustion chamber cc on peanut port heads. My heads are #360. I was wondering if switching to 049 heads would make any difference in compression ratio? Up or down. I was wanting to make a head change to large oval port with bigger valves. My motor is 1990 454 hardin. Has anyone made this swap with good results? Thanks
    Kingman/Golden Vly, Az
    Quote Originally Posted by cole ss View Post
    Does anyone know the combustion chamber cc on peanut port heads. My heads are #360. I was wondering if switching to 049 heads would make any difference in compression ratio? Up or down. I was wanying to make a head change to large oval port with bigger valves. My motor is 1990 454 hardin. Has anyone made this swap with good results? Thanks
    IMHO, a switch to 049 or 781 would be a great upgrade ...a switch to 990's would be even better (oval vs rect)...all of them work very well ...whatever you decide, just, get rid of the peanut heads...you will be way ahead of the game! ...just my .02 cents
    FastRat
    Menifee
    Dont' worry about compression loss. I've ran 990's on 8:1 motors and had great results. The hp gain switching to the 049 will far offset any compression loss. Do you already have some 049's or are you still in the market. There are way better heads than the outdated tech of the 049.
    Keith...
    Rochester, wa.
    I have the heads apart and being checked at shop. I thought about 990, but I am only doing a mild build. I just want to get away from the restrictions of the peanut port. I want to use my stock short block which is in great shape. Keep my stock logs. Rectangular ports would problably be over kill. I am worried about to low of compression and what would be a good cam. I am looking for over 425 hp. I love my boat, but with hauling more teenage kids I want a little more power. Thanks
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    I have the heads apart and being checked at shop. I thought about 990, but I am only doing a mild build. I just want to get away from the restrictions of the peanut port. I want to use my stock short block which is in great shape. Keep my stock logs. Rectangular ports would problably be over kill. I am worried about to low of compression and would be a good cam. I am looking for over 425 hp. I love my boat, but with hauling more teenage kids I want a little more power. Thanks
    Lower compression could be a great deal, dump a grand and put a b/m blower on it !
    [/SIGPIC]
    from the info i have looked at the peanut head would be 118 cc chamber
    and the 049 show up at 119 cc
    but you can put some $$ into putting larger valves and port work into making these heads flow well so get some firm quotes.
    rec port heads would be a lazy at your cubes/compression/rpm range if you are dollars ahead look into hyd roller cam setup.
    Best of luck.
    We settled this on another thread. 8 to 1 BBC IN A JET need 360 heads and a Dart T ram with 2 1050s and a 290 @ .050, .800 lifter solid roller. Others wise your just leaving power on the table.
    California
    Can you still use the long slot stamped steel rockers on that
    Yes, but it is very close, and you have to convert to 3/8 studs
    Rochester, wa.
    Really just looking for someone who has tried this before, and to what result. Would like to use larger cam. Mild by your standards.
    There should be no appreciable compression loss going to the 049. You can buy soem after market heads that will help boost your compression a little. But the chamber size on your peanut heads is probably just as big, if not bigger, than the 049s
    Jul 2010
    What is your RPM range? 049s will have a bigger chamber than the 360s.
    Rochester, wa.
    I am looking to be in the 5,000 range more or less. I would like to keep my stock bottom end. My boat runs 57 @ 4,450. It weighs about 2500lb. I just want a little more get up and go. Love to get to about 65mph. Miss having a nice sounding cam.
    Jul 2010
    I dont know on a boat because of the exhaust problems, but a 5000 RPM engine with a nicely worked set of peanuts are the way to go, I get 560 HP @ 5600 RPM 580 TQ with a 9.6 comp 467 with a [email protected] flattappet hyd cam, and it makes power right off idle, and remember that could be 580 HP on Reher Morrisons dyno. If your set on the bigger ports a 781 has a smaller chamber than a 049, 820s or 148s would also work well, but not as good as a killer set of peanuts. One also has to keep in mind porting production heads on a boat is probably not a great idea.
