Lets see your scoop trays
Results 1 to 14 of 15
    Feb 2009
    MANTECA
    Default Lets see your scoop trays
    I made my own scoop tray for a fiberglass scoop, and now I would like to make a nice transition for the air going into the carbs. The tray sits on two 750 cfm holleys, and when I made it I decided that I didn't want to mess around with cutting holes for the float adjustments etc. I bought two 1-1/2" aluminum spacers that sit on top of the carbs and welded the tray to the spacers, so it clears everything. The problem that I see is the 90* sharp corner at the entry. Does anybody know of some small air bells that would fit in there? Or better yet, what is everybody else doing inside their scoop? Or is it top secret?
    Thanks,
    Chris
    Kingman/Golden Vly, Az
    Quote Originally Posted by bigdog View Post
    Thanks,
    Chris
    Pics of your set-up would be nice, so we can help you with your problem! ...just sayin'
    FastRat
    Derby, Kansas
    Thanks,
    Chris
    Here's a few pics of mine, not sure if the transitions help or not but it made sense to me. I think once the choke horns are cut off or a switch to the HP main bodies it will probably be more beneficial but who knows.
    Senior Member bobbo541's Avatar
    San Ramon, Ca
    jegs sells these they are from quickfuel.
    Mohave Valley/Quartzsite
    Nice work Loren!!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Be Nice!!!
    Derby, Kansas
    I know but I'm really not much good at anything else either.
    Feb 2009
    MANTECA
    FastRat
    I knew that was coming I was thinking it while I was typing, but was too tired last night to post them. I will get some up tonight.
    Feb 2009
    MANTECA
    Carnivalride, That is nice. What did you use to get that radius in there like that. I guess I could make somthing out of fiberglass. The finished scoop looks awesome. How much do you charge......
    Feb 2009
    MANTECA
    Quote Originally Posted by bobbo541 View Post
    Bobbo, I was leaning towards using a pair of these, but hated the thought of cutting them up to fit into my scoop. I still might use them, but I was just looking for something a little smaller.
    Chris
    Feb 2009
    MANTECA
    Here is a shot looking down the carburator. You can see the sharp edge as the air is entering the carb. This was just to get to the lake one day (2 years ago) and I am finally getting around to fixing it.
    Thanks for all the suggestions,
    Chris
    Denton, TX
    Chris
    Does it really make that big of a difference Performance wise? I could see if the boat was going 120 and you were looking for every tenth. Sharp edge vs Transition is flowing how much more air? Maybe 2-5 CFM more? If that?
    How much is it disrupting the airflow?
    Derby, Kansas
    Default Yours looks good to me
    Chris I used a router to cut some high density particle board I had laying around to get the basic shape and then spread filler with piece of aluminum cut to the radius I wanted. I then sprayed it with automotive primer, blocked the top and sanded the "bells" by hand with a foam pad behind my sand paper. It was then painted, wet sanded, buffed and then waxed. I bought the scoop and just added the flange to the bottom. As far as making the tray I'd have to check and see how bad the mold is my son knocked it off the shelf but I believe it's a 9-3/8" center to center on the carbs.
    Chris
    Depending on the air requirements of your engine I'm not sure my base would gain you anything. Isn't the scoop supposed to direct the air straight down to the carburetors? I know on mine it really doesn't need 1500cfm so would another 100cfm (if that) make any difference? Your tray looks good so I'm not sure I'd spend the time to change it unless you just want to.
    FWIW look at some of the pictures of the ones under the scoops Kevin Felkins makes, the metal trays under those look very similar to yours except most of them are for dual dominators.
