Storing Carbs
Storing Carbs
    Mar 2010
    Clarksville, TN
    Default Storing Carbs
    Hey guys, I got 1 for ya .. I was lettin a buddy borrow a carb and I got it back and won't be usein it for a while .. What is the best way to store a carb so its not all messed up when I go to use it again ??? I was thinkin to take it apart and get all the gas out of it and let it air dry and spray it down real good with the same fogger I use to store the motors .. Any ideas ???? Thanks
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    Sounds like a plan, maybe crean them out good with Gumout spray before you fog them to get any varnish out.
    i use stabil 2 stroke fogger, after draining of course. if im at work i use wd40, really anything not to volatile will keep the pump diaphrams from hardening you'd think
    Mar 2010
    Clarksville, TN
    Thanks guys
