GM GEN VI Timing cover removal question
    Member Mach80's Avatar
    Phoenix, Az
    Default GM GEN VI Timing cover removal question
    Have any of you found a trick to remove the timing chain cover from a 454 MPI Gen VI engine without removing the oil pan. I would like to do this in the boat rather than removing the engine. Thanks!!
    Gone
    Sparks, Nevada
    Oops. Read wrong and thought it was Mark IV.
    Never mind.
    member
    Nov 2008
    Yes it is posible but you must loosen the pan bolts to give you the room. Your pan seal is one piece rubber and if in good cond will seal again.
    Kingman/Golden Vly, Az
    Quote Originally Posted by Mach80 View Post
    if your purpose is so you can change the cam...put a 2 piece cover on it...problem solved! ...just sayin'
    FastRat
