What gen. Block do i have?
Results 1 to 14 of 29
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default What gen. Block do i have?
    I'm buying a running 454 chevy that came out of a 76-78??? pickup. any idea what gen block i have? I'm looking to start collecting parts for a build up this winter and want to make sure i have the right ones. thanks
  2. #2
    RAT PATROL rich s's Avatar
    S central Pa.
    What gen do you want?
    it should be a mark IV
    be carefull they don`t slip you a 366
  3. #3
    Aug 2010
    Albuquerque NM
    thanks for the advice. I'll be sure to check the casting #'s
  4. #4
    Kingman/Golden Vly, Az
    Quote Originally Posted by mrjoshua View Post
    do check the block casting #...it could be a 396! ...just sayin'
    FastRat
  5. #5
    Aug 2010
    Albuquerque NM
    Is a tall deck preferable for a 468 or 496 build or does it make much difference?
  6. #6
    California
    For a 468 no, for a 496 it could be a plus, not necessary though. But the only talk deck block your gonna want for that build is a 427, like said above make sure its not a 396 or a 366. Also if you find a virgin block theres no real point in going .060 over, just my .02.
  7. #7
    Aug 2010
    Albuquerque NM
    I will check all casting numbers Are they located in more than one place? Also if it is a 454 tall block is the only way to tell is by measuring it? or will the #'s indicate that. also i've been told it's all origninal miles so probably never been bored out. if you only go .30 over you get a 468 correct? but if it"s a tall block will that be a problem?
  8. #8
    California
    The casting numbers should be on the back of the block on the left hand side above where the bell housing mounts.
    There were no production 454 tall decks produced, if it is a 454 its a 9.8" deck block. A 454 .030+ or a 427T block (10.2" with a 4.250 bore) with a 4" stroke crank, 6.535" rods (.400+) and a .030" bore will net you 460cid. But if its a 427T your going to have to replace all the internals anyhow so why not stroke it.
  9. #9
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    What would a 1995 454 out of 2500 chev. 4wd. be? Thanks.
    Besides a boat anchor.
  10. #10
    Aug 2010
    Albuquerque NM
    What supplier of stroker rotating assemblies would you guys recommend? Cost is an issue so i can't go $3-4K on a kit.
  11. #11
    Senior Member Bruise Brothers Dad's Avatar
    Pomona,Ca
    Eagle comes to mind. Many combinations at resonable prices for the budget minded
    Need help finding this 1973 Sanger 18'6" bubble deck mahogany bottom and stringers I was living in Pomona when I sold her in 1979. Just wonder if she still exists
    Update Found my old Sanger 12/7/14 in Reno.
  12. #12
    Quote Originally Posted by jorndy View Post
    It wouldn't be truck block. If its original to the vehicle, its a 454.
    ProComp!
    EDIT; BECAUSE JBP SAID I NEEDED 3 MORE SO i ADDED 4 AND A JUST FOR MEASURE
  13. #13
    Aug 2010
    Albuquerque NM
    cool I'll look into it. thanks
  14. #14
    California
    Gen V also
    ProComp!
    Now thats just wrong...you need at least 3 more of these
