advance or retard the cam
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 50
    Jul 2009
    Default advance or retard the cam
    whats the purpose ? or is it just to fine tune to a specific engine ie. stroker long rod what? just kinda confused about it thats all.
    waterloo
    This is going to get good real fast.
    Wags
    OK, I will start with a general answer. Generally advancing the cam will help lower rpm range, while retarding it will help in the upper ranges. It will also affect piston to valve as it changes valve events with regards to the crankshaft.
    Gone
    Sparks, Nevada
    add:
    4 degrees generally enough to "feel".
    more than 6 degrees "hurts all over."
    Next
    Not much to add to those two answers.
    Jul 2009
    aaahhhhh thanks very very helpfull and in words i can understand
    Gone
    Sparks, Nevada
    oh come on.
    Advancing the camshaft tightens the " " piston to valve clearance.....while loosening
    the ".....
    Generally speaking:
    if your engine makes 550 hp at 6,000 and falls off past there ( assume cam is straight-up), retarding the cam will extend the rpm range a couple hundred rpms. Advancing the cam will allow the engine to make more hp and more trq at a lower rpm and falls off faster or sooner than running it straight-up.
    S CP
    waterloo
    oh come on.
    the ".....
    I know! I know!
    Wags
    Generally speaking:
    S CP
    And why is that?
    Lake Havasu az.
    Quote Originally Posted by lowlow62 View Post
    455 olds..v-drive w/40 gear 11 3/8 x16 dog ear
    -4 ig. [email protected]*spun prop 3900 at the hit and pulled 5300 easily
    0 [email protected]* spun prop 40-4050 at the hit and pulled 5300 but barely
    +4 ig. tim. @ 36* spun prop 4400 at the hit and was all done @ 5200
    added 2 more degrees ig. tim. 4475 (about) at the hit and was done @ 5200.
    +4 is where i wanted to be with a 5K redline
    Sheriff Joe Arpaio
    oh come on.
    the ".....
    Pick me pick me!
    Menifee
    Sometimes you have to advance/retard the cam just so it's put in straight up.....
    Keith...
    Quote Originally Posted by Sold honda.bought hondo View Post
    Did I miss something ? He asked about cam timing not ignition timing
    S CP
