Roller Rockers
Results 1 to 14 of 30
Roller Rockers
    Default Roller Rockers
    Whats a good rocker arm to run? Aluminum,steel,?? Im gonna stay in the $200-$400 range for my BBC
    crane golds then!!
    I just bought a set of these Cranes. wide body tapered to clear angle valve covers.
    I was told thats what's installed in all their engines.
    https://teaguecustommarine.c7.ixwebh...hqu3epvepo1ud3
    San Diego, CA
    Quote Originally Posted by Blue View Post
    If you are gonna run a radical cam and adjust valves often. Get a shaft rockers set up from JESEL.
    Otherwise, get the Crane Gold aluminum rocker arms and forget about it.
    those are nice! now take what you have left over from the 400 and buy a cheap girdle set-up
    I have a girdle set and ARP studs so with the new Comps I think Im set unless someone has a better set in mind
    Crower Stainless Enduro's.
    Sleeper CP
    Newton Ks.
    I personally don't like Aluminums. With aluminum's fatigue fact of life, they WILL eventually break.
    I'm very happy with the Comp Hy-Tech Stainless Steels I am running, but they are out of your budget by about $75 (unless you find a used set for a good price). Had mine overhauled and still spent less that a new set of Comp Pro Magnum Steels ($290 a set).
    H.L. Mencken
    Senior Member hotbo's Avatar
    lake Ouachita AR
    smokin you always are against aluminumi have have never had a single problem with them eve with high spring pressures.i can understand that the other way is alot better steel or shaft mount jeselbut in reality there is nothing wrong with a good qaulity set of aluminum rollers.many peeps run them and have for years.my rollers are cam dynamics been on this mill for about 5 years run it hard seat pressure is moderate and they perfrom flawless.might break someday,ohwell
    Lurker
    NC
    Stud mount, go steel.
    Aluminum will work fine, but you can have better piece with a steel set at a comparable price!! Strength, less deflection, better all around!
    If money isn't a big concern, go with a Shaft type. T&D is nicer than Jessel (ratio/geometry ect.) IMHO!!!!!
    Top of the line would be shaft mounted steel but.......$$$
    Default Bingo
    Sleeper CP
    That is what we're running in the 89 boat now. We ran the old, 20 or 30 years old), Crower steel. I sent them back to Crower 2 weeks ago, and DJ called yesterday to say they are kinda worked, and VERY old. I'll replace those with another set of Enduros cheaper than having the old ones rebuilt......I see shaft rocker failures on a regular basis in boats that get wrung out.......MP
    LOUD BOATS SAVE LIVES
    lake Ouachita AR
    those are perfect
