Ported Oval vs. JEG's Aluminum Rectangular Port heads
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 48
    Sep 2010
    Tucson, Az
    Default Ported Oval vs. JEG's Aluminum Rectangular Port heads
    I'm new to the jet boat thing this year (21' Omega Open Bow, jacuzzi jet) and wiped out some lobes on the cam (Hydraulic flat tappet) a few weeks ago. I'm going to use this as a chance to upgrade. I have a BBC (468, mark IV, 2-bolt main) with a set of ported (bought them that way) large oval port closed chamber heads (milled to 96.4cc) with slightly dished pistons on there now. I also have a set of stock 781 casting (extras), a couple extra 2-bolt blocks, and stock forged crank. I have the opportunity to upgrade to Manley rods (+.250"), 30 or 50 cc dome forged pistons, roller cam and lifters, rev kit (the cam included is a new .726"/.720" lift 284/290 @ 50 with a 108 LSA), Weiand Team G intake, and a set of Jegs Aluminum 119cc rect port cylinder heads (2.30" intake, 1.88" exhaust valves) for a very reasonable price. These are used, but I am going to have all of the parts checked out at the machine shop prior to purchase to verify that the are all sound. The questions i have are: -Has anyone ever used these heads? feedback on them? -Max compression ratio for aluminum heads on this setup? -What is the minimum lobe separation angle LSA for logs vs. headers? (I think the one included is too low from what I have read) -Any other info that would be useful would be very much appreciated! Thanks!
    cfm
    cfm is offline
    Those heads are Canfields.
    Wowzer does that cam have a lot of duration. Need more info on what you are planning to build (rpm range, compression, how to be used, etc) but chances are with that small of a motor and even built for drag race only that cam should not be used. Logs way,way out of the equation.
    Derby, Kansas
    If I read this right you have a 21" open bow jet, if so I would think you would need power at or before 6000rpm. Is this a pump gas build or are you planning on running better fuel, because the 50cc dome pistons sound like way too much, the 30cc dome ones would be pushing the compression limit IMHO even with open chamber aluminum heads, probably 10.5-10.75:1 with a 119cc chamber. The cam you mentioned sounds like way too much duration for this build. What do you have for exhaust on this logs or something better?
    Aug 2010
    El Cajon
    Use the Jegs heads, Canfield made them and are very nice heads for the money.
    Southwest corner AR
    Are the heads that Jegs sells now still Canfields? Not tryin to jack! WT
    WT
    WFL Crew!!!
    I believe he said they were used heads. Jegs heads are no longer with the exception of any left in stock. The Canfields are coming back. Don't know if they will be supplying Jegs, but the heads are coming back
    With the 2.300 valve you don't want to use the jegs heads. Your engine will be a dog unless you want to turn 8500rpm. Chances are they're the 350c intake, not the 310. Either way, the 2.300 valve is way too big for what you're doing. The 781's with 2.19/1.88 valves and a good bowl blend will be a much better choice.
    Sep 2010
    Tucson, Az
    I believe the Jegs heads have 350 cc intake runners. I was shooting for 10.5:1 or so compression. I think the 50 cc dome with .060 head gaskets and .035 deck gives about 11:1 with 119 cc head if I recall the calcs right. The cam doesn't look like the best choice, but I'm especially interested in whether the heads will work for the application. I know they are really for higher rpm use normally, but it is a budget builld and I am trying to use what I have available without too much added work/cost. The feedback is great so far, any more is appreciated!
    Quick Jets says the heads can never be too big. But when he said that, I don't think he was thinking about a 21 ft Omega with a jacuzzi.
    Like Steel said they are big and will never get anywhere near the flow velocity they were made for at the RPM you'll be turning. Add to that a cam that is way big, and it becomes a double boggie.
    and I don't recommend you running the piston .035 in the hole, plus a .060 gasket for a total fo .095 in the hole and then throw pump gas at a 11 to 1 motor. The combo is screaming detonation!
    Sep 2010
    Tucson, Az
    I also have a set of Icon IC 779 pistons (18cc dome) with like a half hour of run time, but could not run the +.250" long rods. Of course I can always buy a set of pistons to match the application if the heads will work...
    Derby, Kansas
    Quote Originally Posted by uawrestler View Post
    Will they allow a 468 to start and run......... yes
    Will they work well on a 468....... no
    You're not getting it that a 468 in front of a jet pump is not going to run in the rpm range where those 350cc runner heads or that 284/[email protected] cam want to run. In fact the combination you're proposing might run slower than what's in there now.
    Ralphs club member LSXINDUSTRIES's Avatar
    Dec 2009
    Van Nuys, CA
    108 LSA is super tight for a cam that is pushing 290 degrees @ .050 That is a huge cam that will run like
    “I am on a drug. It’s called Charlie Sheen. It’s not available because if you try it, you will die. Your face will melt off, and your children will weep over your exploded body.”
    Ok, since you asked, here's what I'd suggest. Freshen up the 468 as is, put it in the boat and have a blast skiing/tubing/hanging out. The boat you have is perfect for that. The parts you have are too mismatched and the boat you have isn't a good choice for high HP anyway. Best of luck to you....
    Junior Member Lotsahorsepower's Avatar
    Apr 2010
    Listen to David.
    That is really good advice he is offering you.
    Sometimes your money ahead to just say no.
    You are never alone
    with Schizophrenia.
    1978 Sleekcraft Jr.Executive
