Distributor install problem
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 52
    Mar 2010
    Default Distributor install problem
    Hello everyone, I am currently having no luck getting my distributor to drop past the cam shaft gear. I've tried turning the motor over to get it to drop but it doesn't seem to want to cooperate. I"m running a brand new msd pro-billet distributor with a msd bronze gear (this is the first time i've ever tried installing a dist. with a bronze gear). I don't know if there is any "trick" or not in getting the dist to drop due to having a bronze gear, or if installing a dist. with a bronze gear is inhearently more difficult or not? Any suggestions, advise, experiences, or help will be greatly appreciated at this point! Thanks in advance.
    Ralphs club member LSXINDUSTRIES's Avatar
    Dec 2009
    Van Nuys, CA
    Quote Originally Posted by h2ospeeder View Post
    Is the oil pump driveshaft keeping you from dropping in? You probably already know, but you have to clock that drive shaft at the correct orientation to get the distributor to engage fully and drop all the way down. Ive had those damn shafts lean to one side or another, and the distributor was a absolute pain to put in. Its gotta be fairly centered in the hole, and clocked to the right orientation
    “I am on a drug. It’s called Charlie Sheen. It’s not available because if you try it, you will die. Your face will melt off, and your children will weep over your exploded body.”
    Mar 2010
    thanks for the suggestion, yes I rotated the oil pump drive shaft many times thinking that that was the problem, but I'm thinking that i am not even getting to the oil pump drive shaft because after everytime i pull the dist. back out, the oil pump drive shaft doesn't look like it's been moved or touched for that matter, and guessing my dist is still sitting at least an inch to a inch and a half from seating is making me think that some how it's not fully engaging or getting past the cam shaft gear?
    Mar 2010
    but supposing that the shaft is leaning to one side, how would i correct that without pulling to motor and pan?
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    What motor do you have? Some of the Ford motors I had to rock the crank to get every thing lined up then re-check the set up when it fell in.
    Aug 2010
    Look down the hole first with a flashlight before you do anything.
    Mar 2010
    the motor is a 540 bbc, and i definetly would look down the hole before pulling it. Is it possible, if need be, is it possible to pull the oil pump drive shaft out of the distributor hole and reset it or?
    Sep 2010
    Try putting the dist. in with out the shaft if you can and see if the dist. will drop in to the cam. Shouldn't be a prob to at least make sure that the gears will mesh.
    Mar 2010
    I can do that, but again is it possible to easily pull the oil pump driveshaft out of the dist. hole? If so how would i go about it? and what about putting the oil pump drive shaft back in, is that possible also through the dist. hole?
    Sep 2010
    My main thing was FE block Fords and we had a snap washer that went on the pump shaft to keep it in the pump. The last Chevys I worked on were small blocks and they had a sloted oil pump drive on them and that was about 35 years ago.
    Default Gm to aftermarket
    Look at the bottom of the dist shaft. Then look at the stocker. The stockers have an "easy entrance" in the ID of the shaft, some aftermarkets do not.... I have never heard of, or had any issues with the gear engagement, but it is possible the cam gear location is off due to lateral movement of the camshaft... Try the stocker again....and/or, do some comparisons of the two... The oil shaft will prevent the last 1/4 to 1/2 inch of "drop", not much more....AND rotating the engine slowly by hand always works.......
    Ray
    LOUD BOATS SAVE LIVES
    Default Noooooooooooo.....
    DO NOT PULL THE SHAFT OUT THE TOP..... First, if it has a plastic sleeve, you will pull the shaft out of the sleeve, and the sleeve will be lost in the engine... If the shaft has a steel collar/sleeve, it is pinned on, and won't allow you to pull the shaft out the top.. What gen is the engine?......
    Ray
    Sep 2010
    Ray
    I know on my Fords I always was in the cam with the dist. gear before I cought the oil drive shaft and that was about 1/2" drop on the shaft.
    Mar 2010
    it should be a gen IV, it's a merlin block and i'm running a melling 10778C oil pump with the hardened oil pump shaft.
