jet sizes
Results 1 to 13 of 13
jet sizes
    Senior Member wajetboy's Avatar
    Auburn, WA
    Default jet sizes
    i just finished my build and wanted to get any idea of what jets i should start out with, heres my build
    521cid
    victor intake
    9-1 compression
    eldebrock 100 cc heads
    comp cam dur at .050 intake 262 exhaust 272 lift intake 682 exhaust 682 112 lobe sep.
    6al ignition
    i am running a 3 curcit 1050 dominator, motor is also in a jet boat
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    i'm runnin 88 in all 4 corners of my 3circuit dom. 1050hp, good luck tuning the 3rd circuit i'm having fun with it
    Auburn, WA
    forgot to add i dont have pv's
    Las Vegas
    540 ci
    1050 dom marine
    33 DEG TIMING
    93 squares
    4.5 power valves
    BEST MONEY EVER SPENT WAS ON THE AIR/FUEL MEATER
    350 BUCKS
    MUST HAVE A BUNG PORT IN THe EXHAUST ELBOW.
    OURS RUNS FROM 1000-5600 @ 12.5
    COOL PROGRAM EVEN PLOTS IT FOR YOU
    DID IT EVERY 10 SEC AND 2 HOUNDRED PRM'S
    Quote Originally Posted by scarabrick View Post
    540 ci
    1050 dom marine
    33 DEG TIMING
    93 squares
    4.5 power valves
    350 BUCKS
    what kinda meter set-up? sound nice, i've gotta cheapo set-up but it doesn't store data at all, that'd be nice to use
    Las Vegas
    My bro got it and i'll and find the info.
    Hooked it up to the laptop and did the testing wed of this week.
    very simple to use.
    I think when we get our BIG motor built we're going to put a sensor on each exhaust elbow.
    usually they use them on the dyno to fine tune. however we wanted to also do it in the real world with the prop on we're running. We wanted it a little lean around 13.2-13.5 at idle so it won't load up
    Las Vegas
    innovative products
    innovative air fuel meter
    "g 2 "
    http://www.innovatemotorsports.com/products/MTS.php
    Auburn, WA
    i have a air fuel mixture with the clamp to clamp to the end of the header, just forgot to bring it with me, i keep hearing that is going to be the only way to get the air bleeds dialed. thanks guys
    Auburn, WA
    [QUOTE=scarabrick;136580]innovative products
    "g 2 "
    http://www.innovatemotorsports.com/products/MTS.php[/QUOT
    i have one of there units and am very happy with it
    Newton Ks.
    Quote Originally Posted by wajetboy View Post
    521cid
    victor intake
    9-1 compression
    6al ignition
    What carb do you plan to use (list #)? Start with STOCK JETTING, work from there.
    H.L. Mencken
    Auburn, WA
    i think i got it figured out it was the air bleeds. i pulled out the intermediate one and what a difference.
    W.B., i ended up using a 5/64ths drill bit on my bleeds to get it sweet i'm currently at 88 at all 4 corners, 5.0 p/valves in frt and back, and the 3 circuit bleeds drilled out to 5/64ths sumbiatch sounds goooood now no more bat ba bat ba bat
    Auburn, WA
    i just got some 78 (5/64th) bleeds today to start out with. if we would just get some good weather here i could go test, it snowed last night and was 84 last saturday.
