retainer plate for a solid roller cam
Results 1 to 2 of 2
    Default retainer plate for a solid roller cam
    Do I need to run one?I`m thinking yes since I need to set the cam end play at .003 but my water pump is driven off the cam but I`m sure it would be more than .003?Thanks again guys,Tom
    Unless your running a GEN 6 motor, there is no such plate.. You use the water pump to take the thrust. You adjust the length of the drive shaft on the pump. or if you use an extention piece between the pump and the cover, you can amchine the extention piece.
