no spark to plugs on a 58 392 hemi
Results 1 to 11 of 11
    Mar 2010
    Default no spark to plugs on a 58 392 hemi
    so i go to crank my boat up that has been sitting for a few years. and try to turn it over. its getting spark all the way up to the coil but from the coil to the dizzy. the points are sparking and are gapped correctly.
    could wires be an issue? i was just starting out simple and replacing cap, rotor, and wires.
    any other suggestions?
    Senior Member cakeeater ed's Avatar
    huntington beach ca.
    condenser
    Quote Originally Posted by eightsevenzero View Post
    This makes no sense. All the way to the coil? spark come FROM the coil. do you mean it has 12 volts to the coil? That means very little. Your coil could be toast. specially if the "key" was left on for some time with the engine off, the last time it did run. replace the condenser first. Then check the coil. But I say it the coil if you have no spark. condenser usually only effect it a speed. You can lift the neg off the coil (with the points closed)and touch it on and off the coil terminal. If it doesn't spark thru the coil wire, your coil is toast.
    Mar 2010
    no spark coming out of the coil as far as i can tell. i put a static light on the line going to the dizzy and put the wire from light on neg terminal on battery, it wont light up when i crank engine.
    my coil is definitley good, when i put it in my VW its fires right up.
    the coil has the wire from the dizzy going to the neg terminal and line from solenoid to the positive side.
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    If you have 12V to the coil ground out the - side of coil several times and see if you have spark out of coil from coil wire to dizzy. File the points they will get corroded and not get contact.
    SoCal
    Try hot wiring it without the ignition switch also.
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Quote Originally Posted by cakeeater ed View Post
    condenser
    I'm with Ed.
    Im non induced and My turd leaves pretty hard as she sits.
    Sep 2010
    Put the test light on the wire out of the dizzy and go to + side of battery crank engine and see if it flashes, if it doen't then it is in the points or condenser.
    Mar 2010
    problem solved, the resistor was fried. back in business, she sounds mean!
    May 2010
    Pics???
    Mar 2010
    man wish i had time to get some but not today, search my other thread about trying to identify the hull. same boat.
