Nitrous/ piston ring gap
Results 1 to 14 of 39
    Senior Member Amango's Avatar
    Sep 2009
    Default Nitrous/ piston ring gap
    All right N2o guys need a little help. piston ring gap for a 250 shot on top off a 700 HP BBF running on E85? I lifted the top ring land off of two of my pistons last trip out with only a 125 shot second pass boom. My ring gap on tear down was set to .028 too small this was the top ring. I was thinking .008 X the bore size to play it safe when i put it back together and about .002 larger on the second ring? What do you pro N2o guys think. I i'm sprying with E85 not race fuel.
    Thanks in advance
    Quote Originally Posted by Amango View Post
    Thanks in advance
    If you lifted the top land at .028, you may have other issues. You are aware you can left a top land from running over rich. Even more so with E85.
    X2... .028 should hve been plenty.
    Sep 2009
    Thanks! Learn something new every day! E85 tune is new to me. But i can tell you this. Started out way lean just tuning the carb not N20. engine was pulling up to 5600 and then doing the lean popping. as i jetted up rpm increased. Final result was a .156 orifice jet in secondaries and 97 with power valve primary. and RPM was 6200 RPM WOT no popping. Now with N2o engine was surging a little from 6300 to 6400 had 5 degrees of ign. timing pulled out with my nitrous controller. The fuel pressure was et to 6 psi. Very poss able to rich on n20??? i thought it was a lean surge on the second pass. Just because of the carb tunning.
    thanks
    thanks
    Not saying it couldn't be lean either. Just saying unless that ring is sitting right at the top of the piston, .028 is plenty for that shot.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Hmmm.... maybe I should check your IP to make sure this is not a Hat Alias.
    QE 439 Twin Turbo
    Certified Wildman! Sanger Flatbottom's Avatar
    May 2010
    Antioch, Calif (NorCal)
    First of all if you feel surging, it's from being lean... too rich and it will just "lay down" and quit pulling. Second, Nitrous creates oxygen, so if you suspect a lean condition it's because you're not adding enough fuel for the added oxygen the NOS is providing. Third, you should be reading your spark plugs after a steady cruise, then trying your changes (the steady cruise cleans up the plugs) and reading the plugs IMMEDIATELY after your run. E85 is a whole different deal, so I may be comparing apples with pistons... (no pun intended) And I completely agree with steelcomp, .028 is plenty ring gap and I would go no more than that. I also agree with gn7 on other issues causing the top land to come off, and that could be from compression ratio, to piston design/correct application, and the host of other mechanical issues that are possible, although I can't help on the rich E85 issue and don't understand why it would cause that but anything is possible... did it melt or just plain break off? Also piston to cyl wall clearance is critical on the squeeze, a tapered wall would be trouble, but this is based on how much you trust your machinist. Also what ign system are you using and what kind of plugs/gap are you running. I might also suggest calling your Nitrous kit manufacturer to ask for some advise tuning your combo without eating hard parts... Anything you decide to do, verify it with multiple sources before jumping in i.e. engine builder/machine shop, NOS company and someone who you can also verify has had experience tuning NOS setups. Every combination is unique when tuning so be careful & keep us posted.
    Everything electrical has smoke in it.... and it's not done till you let the smoke out!
    My je catalog shows .007 x bore size on top ring and .0075 x bore size on second ring in a race app
    in moderate turbo/n02 .005 x bore and .0055x bore on second.
    I run the .007 x bore for a little safety margin in mine (565) gas ported .043 rings j/e pistons
    what kind of fuel system are you running and what octane fuel??
    I would also check bottle pressure and that the tank is full on every 3-4 pass.some guys are heating there bottles to get the pressure up.
    You may want to send your solenoids in for a rebuild also before you spray it again,cant be to safe
    Thats just me n02 failures can cost$$ big money
    mine only activates during the last 1/4 inch of wot with the button pressed at the same time,also i run a msd timing computer
    best of luck.
    Sep 2009
    Thanks every body!
    Here is a little more info on my build.
    BBF 466
    Compression ratio 12.8-1 Pistons where KB-401 domed Hypers going to forged
    Cam Custom solid roller 665 lift 278 duration at 50
    Heads TFS CNC'd 325 80cc combustion chambers
    Carb 1050 quick fuel E85 conversion
    Spark plugs NGK-8 gaped to .032
    Ignition system is summit capacitive system like the MSD 6AL with Jacobs nitrous master mnd controler that will shut of N20 if fuel pressure drops.
    Fuel system -10 from tanks pulled by a Mallory 250 alky pump to BG 4 port regulator -8 to carb She is getting plenty of fuel Solid 6 psi with N2o flowing and feeding carb. one port go's to fuel solenoid.
    Pistons did just plan break off no melting i will post some pics when i can!
    NO no no! Hats arguement was fuel was the fix all. Fuel took care of all pistons failures.
    Although everything the OP says sounds like a lean condition, the cap was plenty. So there is something else that took down that piston.
    I would like to know if this land failure was a lift, or busted off that apears as a lift.
    These are Jeff Procks words, not mine:
    Failure Modes
    The two most common nitrous-motor catastrophic failures are blown head gaskets or burnt pistons. A blown gasket can be hard to run down because it can be caused by either the wrong air/fuel ratio or detonation (or both, since the two can be related). If you just treat the symptom with improved gasket sealing, there's a good chance the next failure will be with the pistons.
    Piston failures are easier to diagnose. You'd think going too rich is safer than too lean, but if liquid fuel trickles down past the rings, the resulting distress can lift the rings upward. As Nitrous Express puts it, "Many nitrous failures are caused by running the engine excessively rich. Contrary to popular belief, richer is not necessarily safer."
    On the other hand, burning a trough down through the rings into the skirt usually means you are both too rich and have too much timing in that cylinder. "But if you burn a hole through the top of the piston, you are running too lean. If you start the burn and there's nothing left to burn, everything's gone--you'll just burn the aluminum," adds Musi.
    Cantard 71hallett's Avatar
    snow bank
    Where was the cam put when you deg. it? To advanced will do this.
    I have an extremely advanced camshaft and this has never happened to me. OH! did you mean advanced valve timing? Mine is technologically advanced. Kind of like me
    snow bank
    You are advanced in your own special way Bob.
    Mohave Valley/Quartzsite
    Failure Modes
    Exactly Bob!!!! I've done some reading over on yellowbullet and it seems like you can hurt a motor quicker running to rich vs running to lean.. Obviously if you just take the NOS jets out and whack the throttle then it will kill a motor faster.. I run .026" on my top ring with a 125-150HP with the top ring way up the piston 1.125 CH and we haven't experienced any problems (knock on wood)..
    Amango, what type of NOS system do you have and what's the tune up? 6 psi seems a little high to me.. Did you actually flow the NOS system? We run ours @ 5.5PSI.. I would think you would have to have the NOS system way out of whack to lift a ring gland on a 125 shot.. Post this over on www.yellowbullet.com.. They have a Nitrous forum, great info over there!!!!!!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
