Belt drives
Results 1 to 14 of 27
Belt drives
    Senior Member WES...'s Avatar
    Default Belt drives
    which are better and why.... Comp Cams, Jesel, Xceldyne??? thaughts and opinions...
    HOUSE OF FLATS LANDLORD
    There is a no contest winner here. The Xceldyne. With the ceramic front bearing and seal assembly, balanced hub, o-ring cover, and easy end play set up, it is the ultimate set up.It is also the most expen$ive. I perfer the Comp over the Jesel because of the ease in setting up the end play, and and the fact that it uses an idler for line bored blocks.
    Word of caution! If this isn't a drag only deal, don't do it. Either use a chain, or a Milodon gear drive. The belt is not endurance friendly. And when the belt goes, it goes now!!. A chain will stretch, the belt just fails. Catastophically, no warning. Looks good one minute, shredded the next.
    Green Bay Wi,USA
    wow. Ive got some time on my jesell belt, Should I change them after each season? No wear indication, they just fail? I do know they have a Kevlar version.
    Heat is their #1 enemy. If the engine is enclosed get the white belt! NOW!!! If it isn't, I still suggest it.
    LINK: Jesel belt failure
    B1 Racing cs19's Avatar
    For the price of the belts just replace it frequently, not worth taking a chance. The White rhino belt is the way to go.
    okie, lake Texoma
    does the same belt fit the jesel and comp setup or do you need to get the belt from the manufacturer ?
    H8-2-W8
    [email protected] first pass
    Mar 2010
    Clarksville, TN
    Well chit ... I just bought a comp belt drive for the 540 cause it waz supposed to be the "chit" .... I knew I should have went with the chain ... What kind of use will I get out of the belt before a change is needed ?? Or just change it out every season
    Mar 2010
    Clarksville, TN
    Anybody happen to know how often you have to change these belts on a lake boat ??
    Depends on the hours and the use. You're not going to have a ton of spring pressure or rpm, so you could conceivably get a season out of a belt. I'd change it every year and keep an eye on it.
    Tech line at Jesel told me, not for street use or constant driving.
    suggested if I ran one to change the belt at least once during the season
    So I went with the chain
    #55
    One of the big killers is heat. The white belt is not only stronger, but takes the heat much better. Enclosed engine compartments are much harder on them then say a drag flat. And they don't like oil.
    Senior Member badbug3's Avatar
    Default belt?
    what does nascar run for cam drives?
    Green Bay Wi,USA
    Regarding the jesel belt, would the black be seasonal and the white more than one season. we don't have long summer up here. Open engine compartment.
