more power on my engine
Results 1 to 14 of 18
    Aug 2010
    Croatia
    Default more power on my engine
    hello froam croatia
    i have a engine block 3970020
    it was rebuild this year
    i want more power and i looked for this
    http://www.cpperformance.com/p-12380...am-bottom.aspx
    and
    http://www.cpperformance.com/p-12381...l-ram-top.aspx
    can i set this tunnel ram on my engine ?
    i would set there two holley carbs
    Kingman/Golden Vly, Az
    Quote Originally Posted by ncrncevic View Post
    hello froam croatia
    and
    i think, if your looking for a T/R for a SBC, you can do alot better than that!...if you check the ads on here & on www. Racingjunk.com & EBay & a few other sites, you can find what your looking for...just remember, its gonna cost you $$$ to have it sent to Croatia!!!! ...just saying my .02 cents
    FastRat
    Okmulgee Okla.
    the casting # say its a 200 hp 307 sbc. If you want more power I would look for a larger motor. And damn son, can you even get any parts where your at for an american made hot rod. i dont think your gona have Napa know how where your at.
    Good luck with your endevor
    well the block is GM any ways
    IS UNDER FIRE
    Tri-Cities, TN
    What kind of boat is the engine in?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Aug 2010
    Croatia
    it is a offshore rib
    California
    Not sure if the application warrants one, but the Edelbrock street tunnel ram is the best bang for your buck if a tunnel ram is what you want
    http://www.summitracing.com/parts/EDL-7110/?rtype=10
    Aug 2010
    Croatia
    Quote Originally Posted by Wild Hair View Post
    307 is a 5.0l engine
    but this is 5.7 engine
    Aug 2010
    Croatia
    Thanks for the advice
    and this is for my engine block ?
    Aug 2010
    Croatia
    are two holleys 450 enoughor is it better to set two 650 ?
    Tri-Cities, TN
    Tunnel Rams power ranges depending on the CID, the smaller the higher, in the middle rpm ranges. Lets use 4000 rpm. This is an Inboard/Outboard I am assuming so you have a pretty much a fixed gear ratio and only prop changes can raise and lower rpm. An I/O must be able to go from idle 900 rpm to 5800 rpm or so without a gear change. The best 2 scenerios to do this is CID or positive manifold pressure, ie Blower.
    If you put that tunnel ram on you are going to have trouble getting the boat "moving" because you will have moved the powerband up.
    A good dual plane intake like an Airgap would be a better choice.
    Chris Straub
    Straub Technologies
    Aug 2010
    Croatia
    I have a bravo 1 drive
    I need more horses and more RPM so I can put biger pitch prop
    cfm
    cfm is offline
    Please tell us:
    Boat manufacturer + model /size / weight / performance bottom or ?????
    Current engine build now - carb, intake, heads, cam, compression
    What exhaust ?
    What speed does it run now and what rpm ? What type prop and what size ?
    Aug 2010
    Croatia
    I am now rebuilding the boat
    boat is 20 feet long
    it will have about 1200 kg with the motor
    Aug 2010
    Croatia
    i buy the tunnel ram edelbrock 7110
    witch carb i need
    450, 600, 650 , 750 cfm
    and what brand
    holley ederbrock or something else
    i am lokking on ebay
