New experience
Page 1 of 15 1 2 3 4 11 ... LastLast
Results 1 to 14 of 201
New experience
    Colfax, Ca
    Default New experience
    Last time out the engine started making a sound deep in the engine. Pulled it and found this.
    #2 & #3 plugs, rest looked fine.
    Turned it over and found this!!!!!
    Right side
    Left side
    Broken crank!!!!!! New one for me!!!
    what balancer are you running? is that broken behind #2 ?
    When they break, its usually between the rod pin and the main on the pin arm. More common behind #8, because every bit of torque gets transmitted through it. When they break up there, it usually a flawed crank, or a junk damper. Unless of course this a v-drive running off the snout. Then all bets are off and that doesn't surpise me one bit.
    Cast crank? Scat I beam rods?
    MI
    No damaged other than the crank?
    Feb 2009
    MANTECA
    Looks like a forged crank, with the wide parting line. Whats wrong with the plugs? It looks like maybe the side strap is pushed down on the center electrode? Kinda hard to see in the pictures.
    Chris
    The part line does look like a forging. Would it amaze anybody to learn that there may be some cast cranks deliberately made to look like forgings? I think the plug got like that because those two cylinders gained a little stroke when the crank broke. Either that, or the crank is broke because it got tired of the piston hitting the head.
    wow at least ya caught it early nuff no major damage happened, just a crank and line hone it
    Jul 2010
    n.ca
    Default Not a new one.
    A flex crack. Stock crank& rods. Not suppost to use your engine as a water pump. It doesn't like compressing water.Time for new motor.Nicely done.Learning the hard way.
    huge member jimthetoolman's Avatar
    Elk Grove California
    Default crankshaft
    Hey Fleetimus: I have a brand new GM forged crank part number #14097044 454 gen 5 and 6 if your interested. Jim
    Quote Originally Posted by aquacraft View Post
    Clean your monitor there Aquacraft. 7/16 cap screw rods? Stock? Stock what? 427 medium riser Ford? Cammer Ford? Water will do that. But iot sure as hell won't turn a thru bolt rod into a capscrew rod with a single strengthing rib on the cap!
    Jun 2010
    IMHO Looks like a rod kinda broke too
    Jul 2010
    n.ca
    Default What?
    That is not a ford or a ford 427 cammer. It's a stock chevy 454. You can see the cast mold line mark on the crank. Cast iron , not steal.Nice try, but wasn't born yesterday.I would guess that the block is stessed too.
    Just reading your own post genius. Stock Chevy 454 did not come with capscrew rods. And the rod caps had two strengthing ribs, not one. Ford cammers and medium risers did have capscrew rods. Your right, those are not Ford rods. And they are not stock 454 rods. Get your head out of your ass before you decide you want to school me on a FE Fords.
    Jul 2010
    n.ca
    So someone went cheep and put a cast crank in a 454. Externaly balanced. Waste of money . He says it's 13:1 pistons, on a cast crank. Anyway .
