setting valve lash
Results 1 to 14 of 17
setting valve lash
    Senior Member Skydog's Avatar
    Jul 2010
    Default setting valve lash
    Can some one run me threw it? It is a 600 Chevy with a Hyd cam. Is there a write up on it? Any one know what spec to set them at?
    Thank you
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by Skydog View Post
    Thank you
    I am guessing hyd roller?
    Jul 2010
    Yes
    Jul 2010
    Thumbs up
    Thank you sounds easy! The Only part i dont like is running the motor to make sure lifters are pumped all the way up. How long before they leak down? So how fast do you have to move when making adj? So on a boat motor i am thinking 1/8" of a turn down then bottom the jam nut down to hold her. How tight on the jam nut?
    THANK YOU!!!!!!!!!!!! P.S. Looks like i have to wait till spring to do this so i can run her.
    Jul 2010
    Last thing when i am in there i want to check the springs, what is a good Valve Spring Tester tool? Needs to clear the big tube headers that come up.
    THANK YOU
    Thank you
    Did you change cams! Or pull the heads?
    Jul 2010
    No did nothing motor has about 50Hours on it and never checked.
    Sep 2010
    How much boost ya running with that 10-71 and at what percent overdrive? Just curious.
    Jul 2010
    Not sure on pullys have to look but about 8-10 PSI
    Jul 2010
    Thank you got one on the way!
    THANK YOU
    Check here:
    http://www.performanceboats.com//showthread.php?t=73752
    G-
    Ya know Sleeper, I wish you hadn't posted that. Now I am just pissed off. What are we dealing with here. The attention span a fruit fly?
