Darts new shp pro block
Results 1 to 10 of 10
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    Default Darts new shp pro block
    The BBC cam tunnel is key and with a .400 lobe the base circle size is 1.140 and with a .430 lobe your base circle is 1.089 Using Lunati Pro Mod rods, Oliver, Callies Compstar rods, Crower stroker rods, Scat I beam with 7/16 bolts with work with these cams. The .904 lifter bores make for a win win situation bigger lifter makes for a stronger lifter plus more lifter bore surface area.
    Features:
    - Brand new precision machined, light weight cast iron block.
    - Big block Chevy cam bore
    - .904 lifter bores
    - Billet steel main caps
    - ARP main studs
    - Siamese bores 4.000" or 4.125" (unfinished).
    - Extra thick decks ensure reliable head gasket seal.
    - Blind head bolt holes don't go through to water jacket.
    - Clearance for 3.75" stroke with steel rods.
    - 350 main journals accept commonly available crankshafts.
    - Uses 1981-1985 stock style oil pan and dipstick.
    - Uses stock stamped steel or plastic timing cover.
    - All OE bolt holes for starter, clutch ball, etc...
    - Priority main oiling system directs oil to main bearings first for more dependable lubrication.
    Dart just sent me a pic of the caps and bottom end view of the Pro SHP block if it fits your build contact your local Dart dealer!!!
    31161112 is the 4.000 bore block
    31161212 is the 4.125 bore block
    And their will be no one peice seal blocks availiable because they have no rear main billet cap for one peice seal crank
    B1 Racing cs19's Avatar
    Isnt there a new BBC block by Dart? Any news on it?
    . . . you mean other than the Billet Aluminum?
    Sep 2009
    Dart did come out with a 1 piece rear seal blocks GEN V and GEN IV
    On the Dart Big-M steel blocks Dart has lowered the price by 250.00 I should probably post that info.
    The Right Coast/SE-PA
    Can Cast Iron be 'light weight'???
    Sep 2009
    The CG blocks are light!!!
    The Man cordog009's Avatar
    East Texas
    A little time with some carbide bits and you can lighten them up
    1984 Youngblood TX-19 SOLD
    LAID IN MEXICO
    santa paula, ca
    Default dart blocks
    does dart offer there big m blocks in a gen 6 configuration? i thought they had that option listed on there web page.
    Quote Originally Posted by Wannabe View Post
    Yes new iron block. I thought there was something updated coming out.
    Sep 2009
    Got my Dart order in and had a chance to look over the Pro Block and so far have been pleased with what I saw and the mains were right in the middle, cam tunnel was right at 2.120 and the lifter bores were on the low side and depending whose lifters you are running they may have to be sized.
    To those who have asked about the studs on the outter splayed holes they are indeed 7/16 studs. Sonic test was very good!!
    NOTE we have been seeing a lot of under size roller lifters lately and anyone who is building an engine should measure all the lifters and size the lifter bores accordingly.
    Any one needing a specific picture of this block let me know!!
