496 oil change
Results 1 to 14 of 36
496 oil change
    Lago Vista, TX
    Default 496 oil change
    So it is time to change the oil in the 496 HO. I usually use OEM 25W-40 synthetic blend by Mercury just like the manual states. The store (West Marine) now only carries some crap made by some outfit called "Sierra". So what to do now? Use this or go to Autozone? If I go to Autozone what oil and filter should I pick up? Thanks. Dave
    2006 Advantage 28 Sport Cat BR
    Lake Travis
    Austin, Texas
    The HMFIC HWLaser23's Avatar
    fontana ca
    I do my own oil changes also. I use mobil one synthetic and a k & n oil filter. Never had a prob doin this. U can order quicksilver stuff on line if ur not in a hurry. Quicksilver is merc.
    BLACK SMOKE DON'T MEAN ITS BROKE
    San Dimas
    Mobil one
    El Monte
    Mercury Marine Oil Requirements for Gasoline Engines and Preventing Contamination of Engines with Emissions Control
    If Mercury MerCruiser Full‑Synthetic, 20W‑40 oil is unavailable, use the following lubricants, listed in order of recommendation.
    If you are servicing a catalyst engine, use these for short periods of time only.
    1. Mercury/Quicksilver 25W‑40 Synthetic Blend, NMMA FC‑W–rated 4‑cycle MerCruiser oil
    2. Mercury/Quicksilver 25W‑40, NMMA FC‑W–rated 4‑cycle MerCruiser oil
    3. Other recognized brands of NMMA FC‑W–rated 4‑cycle oils
    4. A good‑grade, straight‑weight detergent automotive oil according to the last row of the operating chart below.
    NOTE: We do not recommend non‑detergent oils, multi‑viscosity oils (other than as specified), non FC‑W–rated synthetic oils, low‑quality oils, or oils that contain solid additives.
    Mercury Full-Synthetic MerCruiser Engine Oil, 20W-40, NMMA FC-W rated
    MerCruiser/Quicksilver 25W-40 Synthetic Blend, NMMA FC-W rated 4-cycle MerCruiser oil
    Mercury/Quicksilver 25W-40, NMMA FC-W rated 4-cycle MerCruiser oil
    Other recognized brands of NMMA FC-W rated oils
    Preventing Contamination of the Emissions Control System
    Catalyst and oxygen sensors can become contaminated, leading to component failure. Phosphorus, found in some marine‑grade oils, and other compounds will damage or destroy a catalyst's ability to clean the exhaust. Catalyst‑friendly oil, like Mercury Full Synthetic MerCruiser Engine Oil, prevents this damage. Approved synthetic oils must be used in MerCruiser engines with emissions control.
    If you are going to use Mobile One, I recommend the 25/50 for Marine engines.
    B & D Marine Performance
    El Monte, Ca.
    The Insurance Guy millhouse961's Avatar
    Santa Ynez, CA
    wholesalemarine.com has the quicksilver stuff and is cheaper than anywhere else I was able to find
    2003 Cobra 270 Razor
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by BDMarine View Post
    That's AWFULLY thick oil for low-HP engines with oil coolers??? WHY sling that heavy of an oil around??
    If that motor was in a 2001-200? GM 2500/3500/4500, it would specify 5w-30 right on the cap.
    Mine runs 25psi at idle and 45 at speed. With 10/30. So, obviously there aren't any clearance issues.
    El Monte
    Did you see the recommended oil for that engine from Mercruiser? 25/40... not 10/30. There is a reason they don't recommend 10/30. The 496 HO isn't in a GM 2500/3500/4500. That is why you don't see the oil cap with 5w-30 on it. These are not the same engine as a street driven vehicle and see WAY more rpm's and load. The bearing clearances are not the same. 25 psi at idle is low for that engine and I disagree with your clearance thoughts.
    The HP range we are talking about has nothing to do with oil weight. It's not about "slinging" oil around. It is about wear and keeping an oil film between those surfaces. Not just the bearings, but lifter bores, piston pins, piston to bore, rocker arms, pushrod ends, etc.
    A 25/50 synthetic flows through the oil system with less resistance than a 20/50 petroleum oil. How often do you think a marine engine will see the oil working as a 50w?
    El Monte, Ca.
    Bakersfield, CA
    Very rarely.
    20w50 at 212 degrees becomes 10w.
    And of course Merc (or any other MFG, for that matter) is gonna recommend/require THEIR brand (or labled) oil! It doesn't necessarily mean it's the best thing for it. It doesn't mean it's NOT, either.
    In the clearances - there's just MORE molecules of a smaller (lighter) oil than there would be with a larger (thicker) oil. If you are trying to walk across a floor with ball bearings spread out on it - your feet would roll much easier on 100 small bearings than they would on 10. The more molecules you can stuff into the void, the more cushion there is. AND, more surface to take away heat.
    El Monte
    Very rarely.
    You missed my point in the information completely. It's not the BRAND, it's the weight I was referencing. Mercruiser recommends their brand for marketing and the WEIGHT for engine demands. Again, Mercruiser engines as well as any properly built marine engine has more bearing clearance than a passenger car engine (among other things). More clearance means thicker weight oil, for reasons that would take way too much time and better suited for the "Dyno" section. I am very aware of how oil works, which is why we recommend different weight and type of oils depending on many factors. This comes from over 30 years of building engines for marine and automotive applications.
    I'm out.
    El Monte, Ca.
    Bakersfield, CA
    I'm out.
    Look. I know you have plenty of experience, or you wouldn't be in the business you are.
    The fact is, any THICKER oil than NECESSARY is doing more harm than good. Boat motors don't run everyday like a car does either. So, the thinnest oil that will suffice is what should be used. It will get to the bearings quicker after long term storage and also during EVERY start.
    Here is an interesting tidbit of information. A 75W-90 gear oil has the same viscosity as a 10W-40 engine oil at 212 and 302 F. Once again, those numbers on that oil can are misleading and certainly add to the confusion I see among automotive enthusiasts. At 75 F gear oils are much thicker than motor oils.
    Again, at normal engine temp, 20/50 is negligibly thicker than 30w. They are almost exactly the same at 212 degrees. So, the thicker oil is only HURTING things during initial startup. Plus putting extra load on the distributor gear and camshaft.
    This is not 30 years ago anymore. Oils and parts have come a long way since then. 10psi PER 1000rpm is what it takes to safely run any performance motor. I have 25psi at 800rpm and 45 psi at 4000. Any thicker oil would just be wasting HP.
    El Monte
    I'm out of this debate. At this point I would check out and let you have your way. However, your statements are not correct. Thank you for the calendar lesson. My knowledge is based on today, not 30 years ago.
    Your 10 psi per 1000 rpm's has been a blanket statement for longer than 30 years and absolutely does not apply to the marine performance engine. That would mean 7 psi of oil pressure at 700 rpm's idle. Good luck with that.
    You refuse to acknowledge the bearing clearance issue. To get right to the point, thinner oil in an application requiring minimally thicker oil will actually be the cause of premature bearing wear.
    AGAIN, we are not talking about a passenger vehicle with .0010 to .0015 rod bearing clearance. It is a marine engine with .0020 to .0028 clearance.
    Your 30 years ago statement is an insinuation that reminds we why I as well as many other people in this business choose to not offer advice on this website.
    El Monte, Ca.
    Lil' Hellyun That Guy's Avatar
    OC
    Yup......right on point!
    Rack em'
    RIP Kenny
    RIP Bobby
    Quote Originally Posted by kilrtoy View Post
    and the mirror sees me and says
    YOU ARE THE GUARDIAN OF MASCULINITY
    Lovin' IT! OGShocker's Avatar
    Maybe you should just mind you own fricken bees wax, next time!
    Quote Originally Posted by The Doctor View Post
    Trying to explain the Iraq resolution to this troll is like explaining calculus to a palm tree.
    Rest in PEACE, Trimm Mann
    B&D Marine ROCKS!!!
    Bakersfield, CA
    For those of you with a stock 496/496HO, the MAIN bearing specs are actually .0011-.0024, other than #5 which is .0025-.0038.
    Rods are .0011-.0029.
    YOU CAN RUN WHATEVER OIL YOU FEEL COMFORTABLE WITH. I have been running what I run for over 200 hours now with no abnormal oil filter trappings. I definitely run it hard when the mood calls for it, and I am quite certain it would have started putting metal into the filter(s) by now.
    As BDMarine says, you can also run it by the book. Your choice. It's a free country.
