Crankshaft Bolt
Results 1 to 10 of 10
Crankshaft Bolt
    Large Member Watch Me Squirt's Avatar
    Anaheim, CA
    Default Crankshaft Bolt
    455 Olds motor. Need to replace the camshaft due to a sticking lifter which caused a lobe to go bad. What size is the head of the crank bolt holding on the harmonic balancer?
    Quote Originally Posted by Not So Fast View Post
    Any time Leaf comes up, my butthole gets sore
    Kingman/Golden Vly, Az
    Quote Originally Posted by Watch Me Squirt View Post
    LMAO...you are jerking our chain...rite!!!!
    FastRat
    Lake Havasu az.
    Mine WAS 1/16 bigger than the biggest socket i had....knocked it loose with a hammer and chisel and ground it to fit the socket i had...And ya, i really did that, and no, you can't tell i did it.
    As for the size.....i guess it was easier to start a thread than it would be to find a measuring tape
    And you do have that special puller to get the balancer off, right?
    Sheriff Joe Arpaio
    Okmulgee Okla.
    I hope your going through the whole motor. A cam making metal is not good. I would do a complete tear down, inspect and CLEAN everything and then rebuild. Let a good machine shop inspect the block and crank. Also new bearings and rings. Know when it goes back in the boat it's right. It takes less time and money than doing it again. Just my 02
    Also a good time to go chevy You have all winter to switch.
    well the block is GM any ways
    IS UNDER FIRE
    Quote Originally Posted by Sold honda.bought hondo View Post
    I just called Websters. Because you just totally re-defined the definition of "cheap, tight ass screw"
    At Home headed to the shop in a bit and will double check and can't double check but I belive you'll find its 1 1/8 , re the failed cam/lifter like already suggested time to strip it down , this scenario is like the "Sneeze in the theater" in the movie Virus, once the metal part degrades to generate particulate everything oiled is contaminated/infected , Tom
    Really? I always looked at it as "make it as you go graphite"
    Ya Know it does kind of resemble that Isky assy lube
    Lake Havasu az.
    Aw come on, you have never heard of rotational mass reduction?
    And that stuff from the cam lobe....on an olds that is bearing lapping compound. That is how you get proper bearing clearances to make the really big hp numbers. You run straight 30wt walmart oil till the cam goes flat....that is how you tell when it right. Replace the cam, use 50wt val racing oil and 2 bottles of GM eos and it's good to go.
    Don't believe me...ask him how much better it runs after he replaces the cam
    Sheriff Joe Arpaio
    Olympia, Washington
    On my 425 it's 1 1/8.
