Reverse rotation jet?
Results 1 to 14 of 25
    Default Reverse rotation jet?
    I just got a call from someone saying they had a reverse rotation BB Ford in a jet boat. Has anyone ever heard of this?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Maybe he converted it back to standard rotation.
    Or he installed the balancer toward the pump.
    QE 439 Twin Turbo
    Southwest corner AR
    Maybe he is talking about the starter! New one on me!
    WT
    WFL Crew!!!
    lol prob pulled the dizzy cap and cranked it, wondered why it was turning backwards
    I dunno...he says the balancer turns counter closkwise when he cranks it over. He seemed to be pretty sure of what he was sayin, but it's the first I've ever heard of a reverse rotation jet pump. The impeller would have to be made opposite, and the vanes in the bowl reversed. He says it has a top mount starter...my guess is he'll fnid out it's not a reverse rotation starter.
    bet your rite, had a buddy put his own starter on awhile back and was spitting out fuel, sure nuff when i asked where he got the starter i gotta "orielly's"
    Southwest corner AR
    Have seen a guy get a starter rebuilt and rebuilder didn't know it was a reverse rotation! Motor would start cranking backassards no startee!
    WT
    WFL Crew!!!
    Never seen a counter rotating BBF but there may be one? Have seen this other scenario Wide track described several times as well though , prevelant with Fords equipt with Prestolite staters , after starter replacement the motor cranks wont start and backfires thru the carb usually happens when the customer takes the starter to XYZ auto parts or.. they give them something that "looks like" what he had , As I recall The only reverse rotation Jet drive Impeller (and bowl) (have pics somewhere) we have have seen was one specially engineered and machined by a friend for a Gas Turbine powered jet boat a few years back Tom
    http://www.gas-turbines.com/squirt_1/index.html
    California
    First question that comes to mind is WHY?
    If there was a reverse rotation jet readily available they could be cool like the GN's and run off the crank snout
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    reverse rotations jets Suck !
    [/SIGPIC]
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    Quote Originally Posted by Lucky View Post
    Good one!
    Using that line of reasoning, normal rotation jets must BLOW!
    Ukiah,Ca
    Depends if your on the top or bottom
    [/SIGPIC]
