Dart Big M
Results 1 to 12 of 12
Dart Big M
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Dart Big M
    Have to rebuild the BBC 489. Am thinking of going to a Dart block to get the extra CIs. If I order the block from a place like Jegs or Summit how much machine work/money will be required before it is ready to be assembled? Will it make a lot of difference in HP/reliability? Money is tight
    You were right with the increased cubic inches. That is your horsepower advantage of the new block. Reliability will be increased, but they do not come all that perfect. And I would get it from Dyno-flo rather than Jegs. You will save about 200 bones right there.
    But make sure you check everything before assembly. Don't assume that just because they are cool, that they come right from the factory.
    Quote Originally Posted by Master Sergeant View Post
    Plan on bore/hone to size, hone lifter bores (usually tight), check align bore (usually good on Darts), check deck (had to deck the last one I did, not square). Budget a grand for machine work, you should (might) have $$ left over..... or not.
    Oh and +1 what wannabe said about buying the block from Dyno-Flo... just don't let them do the machining for you.
    Southwest corner AR
    X2! You might check with Chris Sturab on the forums he made me a good price and they have a 250.00 rebate going on now too! And Yes there is still work to do to the block! Bore mains lifter bores decks etc. all has tight or high tolerances! WT
    WT
    WFL Crew!!!
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    This is what we do to finish machine a Dart Big-M block
    Some block notes:
    I deck all of them to a finished number depending on gasket & desired piston height
    Block needs to be honed with a plate or bored & honed depending on bore
    Bottoms of bores need to be chamfered
    Most need the lifter bores honed, at the least checked
    Most need line honing
    All pipe threads need to be retapped
    Oil return from fuel pump cavity needs to be done
    Core plug holes need deburiing
    CHECK THAT THE DISTRIBUTOR GEAR DOES NOT CONTACT THE BLOCK BY THE CAM. There is a big cast blob down there you may want to relieve.
    You can machine the gear to clear if you forget but it is nicer to fix the block if necessary.
    Check all the timing bolt holes with air, some may go into water. Same with the motor mount bolts.
    We also deburr around the rear main bearing area and also deburr the main housing bores as well.
    Lifters should be present when checking lifter bore clearance as we have seen quite a few sets of lifters that have been under size and with a stock GM bore the oil clearance would have been at .003 to .0032
    Dart has lowered their price on the Big-M blocks by 250.00 and there is no longer any rebate offer on those blocks.
    Jul 2010
    n.ca
    Well worth the money to do it right.
    Sep 2009
    Quote Originally Posted by CNC BLOCKS View Post
    Some block notes:
    I have got quite a few Big M and Little M CNC blocks from Carl. Very good machine work and at a great price. Last Big M sportsman block was just $2345.00 all machined and ready.
    Tom
    3V Performance
    "ENGINES WITH AN ATTITUDE"
    Custom race engines
    Machine shop
    Dyno service
    50HP Spintron
    828-302-4088
    www.3vperformance.com
    MAD FABRICATOR wirsboguy's Avatar
    Sep 2008
    northern IL
    Default big m
    Try ATECO Engines in IL. Bill is a master wholesale distributor, and gets some good deals on them. He will do all the machining in house and ship it to you. Call him at 847-623-2737.
    Good luck.
    "I'M NOT CRAZY,,,, BUT I MAY BE A CARRIER"
    Senior Member g935's Avatar
    Clovis CA.
    Oh and +1 what wannabe said about buying the block from Dyno-Flo... just don't let them do the machining for you.[/QUOTE]
    Dyno Flo?
    I learned a hard lesson trying to save money with them. I figured about a 10K lesson. The machine work and the clearances were all wrong. It's pretty sad when they give you a piece of paper with your motor that tells you to have a professional check all clearances before you run the motor because they are not responsible once the motor leaves their shop.
    Geoff
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
    Winston Churchill
    Sep 2009
    Quote Originally Posted by g935 View Post
    Dyno Flo?
    Geoff[/QUOTE]
    What was wrong with the machine work????
    Dyno Flo?
    Geoff
    I read that twice. And still can't see where it says anything about clearences. Maybe thats why they put the paper in there. Just an indication of the customers they have to deal with daily. They can't read instructions.
    I bought a Big M 540 short assembled from Scott Shafiroff in Sept. They didn't sell me a one size fits all off the shelf short. They were very knowledgble about open water marine cooling systems and how to clearance the motor for it. I started like you pricing basic materials and found that the assembled short cost less than the parts. I paid $4395 for the short less cam - free shipping and Dart sent me a rebate check for $250. I also bought Dart Pro 1 Heads. Dart says the std BB head bolts are fine. Not true there are 4 head bolts that will bottom out and you will blow a head gasket. 4 bolts need to be changed for shorter or 2 hard washers are needed. The Dart block has 4 internal head bolt studs that go into the valley ( add $100 for the kit). SSRE shipped the motor to DHE in Sacto. They delivered everything promised
    http://www.shafiroff.com/shortblocks/540_shortblock.asp
