What's it usually cost
Results 1 to 14 of 17
    Tower Park Resort, Lodi, CA
    Default What's it usually cost
    What does it usually cost to:
    Get a block bored and honed?
    and
    Balance a rotating assembly?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    In California? i don't Know
    In Oklahoma at my shop. 125.00 torque plate bore and hone
    150.00 race balance.
    Bout the same here too.
    AARP Member Rocket-J's Avatar
    Gilroy, Ca.
    Exclamation Price at Callies
    It was over $300 at Callies using all new parts for a full internal balance.
    It cost $375 for a plate bore and hone in Sacramento at Pashoda's.(SP) I am sure I am way off on the spelling. It was another $150 to square and deck the new block. The cost can vary on how far you have to go and what quality of shop you go to. Also, if they use a sonic test on your cylinders.
    Good luck. Al
    Ladera Ranch
    Quote Originally Posted by wsuwrhr View Post
    Where? in your dreams?
    Smile
    I guess you need better friends.
    Next time bring your favorite machinist some beer when you pick up your parts.
    Ladera Ranch
    not everyone gets the bro deal ya know!
    Next time bring some of your machinist's favorite beer when you pick up your parts.
    I've been going to the same guy since I built my second engine.
    Lexington, KY
    Talking
    You bring a machinist beer and they will do almost anything for you. That's how it works where I work. The fridge is always full of beer, of all kinds, you have to do some creative rearranging to be able to get anything else in there. Another plus for where I work is there is a brewery right across the street, so they bring us beer all the time.
    In the good old days it was 10 bucks a hole.
    OK, I'm a little confused. Is it 150 and a 12 pack? Or 300? I suppose I should just make some calls.
    damn, you guys work cheap may have to bring my stuff to you guys.
    my local place(glen self racing) charges like 250 for balancing(doesn't include mallory if needed)
    then its a 150 for bore with torque plate and sonic testing
    100 for line honing
    i usually end up spending 500 bucks on each block i've had machined in the last 3yrs, which is a full work over, including letting them go ahead and put the cam bearings in.
