Starter Options?
Results 1 to 6 of 6
Starter Options?
    Default Starter Options?
    Looking for some advice picking a starter. I'm modifying a bell housing for a top mount starter location. I picked up a top mount starter from one of the board members. I didn't look closely at the picture and it turned out to be a Prestolite 3 bolt starter used by Harmin Marine, and Chris Craft. My original intention was to use a 2 bolt Delco starter. My question is does anyone have experience with both starters, pro's, con's? I've found that the Prestolite is a 1/3 more costly and harder to find than the Delco, but is it a better unit? Since this is something I'm building, I don't want to build the bell housing for one style and end up regretting my choice. Motor is a blown BBC. Appreciate any help. Thanks Greg
    Kingman/Golden Vly, Az
    PLS remember, all top mount starters are CCW ...i bought mine from DB Electrical in Johnston City, TN...it is a 2 bolt starter, which makes for better alignment to the flexplate...just my .02 cents
    FastRat
    Somewhere between Paso & L.A.
    I had a severe duty tilton top mount on my jet( I also have a big box of
    different mounting plates for the same type of starter, and a bunch of rev
    rotation stuff, only had one 3 bolt presto mount block tho and it went with boat- BUT there are quite a few others that might work- pm me, and
    I'll send you a pick of what's left! and no I don't have any more regular
    bottom mount chevy blocks, either
    Default Junk??
    IMHO, most, if not all, of the aftermarket starters are junk and chew up more ring gears than all the stock starters combined... I run a 3 bolt, (horizonal) starter bolted to a powerglide adapter, pushing 13:1 w/ locked out 39* timing, injected BBC, and it never fails...... These are "Joe down the street rebuilds", stock GM type Hi torque starters... I know of many, many "high torque" aftermarket ring gear sheering, "mini" starters.... Too bad they aren't heavy enough to be used for anchors.........
    Ray
    LOUD BOATS SAVE LIVES
    [email protected]
    Ohio
    I got my hi torque Summit starter and SFI flex plate in 2000. Used them on 2 different 12.5:1 BBC, locked out timing since 03 at 36* and starter and ring gear still working. I guess there is good and bad in all products.
    Tim
    I appreciate the input. Maybe I misssed a little on my question. Since I'm modifying a bell housing to become a top mount and can choose either 2 bolt or 3 bolt, is one "better" than the other? Once built that's what I'm stuck with. The Prestolite looks more industrial, but I can't seem to find a torque rating to compare between (2 bolt)Delco and (3 bolt)Prestolite. Delco seems more common, but both are used in boats. I would like to make the decision based on knowledge and not eany, meany, miney, mow.
    P.S. Moneypit , thanks for the blower hub, got it last week.
