GM Forging #3967416
Results 1 to 14 of 17
GM Forging #3967416
    Default GM Forging #3967416
    All I have found so far is that it is forged, 70-71, 454. I would like to know what material, is this a special crank, what it came out of? BTW mine is cross drilled and has a darker color than normal. Just curious, its out in the shop and says "mag OK." Thanks for any info.
    Somewhere between Paso & L.A.
    sounds like an ls-7 1053 steel nitrated crank to me- best gm oldschool
    crank for years IMHO
    Gone
    Sparks, Nevada
    From a book I have:
    3963523 part number was ls-6/7 1053 crank. Crank ID was 3520 or 7416
    3963524 was the 5140. Crank ID was 3521.
    The only # on the crank is the 3967416 and a W50 on the counter weight next to it. What do I gots?
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    In my Chevy book it say's LS6 / LS7, forged 1053 steel, cross-drilled, nitrated....the high-end of BBC factory cranks, good stuff!
    Anyone can pedal a bicycle, can you pedal a flat?????
    Gone
    Sparks, Nevada
    Is this full part number on the counterweight by the rear main?
    Motec.com
    huge member jimthetoolman's Avatar
    Elk Grove California
    Default Crankshaft
    Quote Originally Posted by fireboat607 View Post
    I have a brand new never used one. $350.00
    Yes Fiat, this complete number in on the rear counterweight. To answer the above question of "Pedaling a Flat," I have a Flat bottom Hallett. But I dont pedal it much since it has a Nailhead in it. Or are you asking if I want to sell it or the crank? Or does my boat have pedals, like a Flintstone boat. Or are you using some sort of kool jargon, only being used for the first time.
    I looked at a site that I think old guy was prompting. Im not really interested in a bad ass fuel/engine management system right now. But if I am I will go MOTEC. WTF is going on here. What ****ing crank do I have. Jesus. BTW Thanks Fiat if you got something on this
    Gone
    Sparks, Nevada
    Quote Originally Posted by MACHINEHEAD1 View Post
    Then here's the story...best I can do.
    Best I can figure....this is a remake of the LS6/7 crank. A new forging. If you compare the front counterweight to a "normal" chevy crank...you might notice the counterweight is "smaller" (not narrower). Get a visual by looking at another crank.
    If this is the case...those cranks flex a lot. I bought 3 of these new (same part number as the "old" LS crank) and all 3 motors they went in had bearing problems. One was in an unblown alcohol altered, One in a monster truck deal and one in my own blown alcohol car. I toasted bearings first (one pass).
    I put some rediculous clearances in my motor and it continued to live. I loosened the other motors up and they too stayed alive.
    So if that proves to be what you have...be aware of that.
    The old cranks just had the ending of the part number on the first throw of the crank. These new ones had the full part number on the rear.
    I bought these in the 90's....want to say about 1997.
    hey Fiat, does that mean that the newer ones that you called remakes
    are possibly not the same material, prob 5140, instead of the 1053steel
    that the "good old ones" were made from?
    Gone
    Sparks, Nevada
    I wish I knew. They did show them as 1053 in the 97 catalog.
    New here Beer:30's Avatar
    Bakersfield, CA
    No no. He was saying go to "Mortec" website. The last time I did, though, it was no longer in operation . Anyway it had all of the SBC/BBC casting/stamped numbers all listed and easy to sift through.
    Yes - MOTEC is an outstanding management system. Coil per cylinder, etc. Nice.
    Just do a google search on your crank number and you will find all you want. It has already been ID'd here, but if you need more assurance - just search on it.
