E85 Plugs
Results 1 to 2 of 2
E85 Plugs
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default E85 Plugs
    How much colder will the heat range of my spark plugs need to be from Autolite Ar3933 for my E85 swap? Also, can I gap the plugs the same?
  2. #2
    Start with your standard gas tune up.
    Don't increase timing, and don't change the gap. The way this works is simple. The gas in the E85 lights first, then it makes the alcohol light. So changing things to more of an alcohol tune-up does not work like you think it would.
    It acts like standard gas when dealing with ignition.
