Intake for TN -pics-
Results 1 to 14 of 21
    Default Intake for TN -pics-
    Here's some pics of the intake for TNYoungblood's 540 project.
    Mock-up for port match:
    Hellooooooo down there!
    Pretty rough form the start...Edelbrock needs some new sand.
    Gettin after it...this makes a big mess:
    End results:
    continued:
    Plenum looks a little "happier"
    Here's the plenum spacer:
    On the flow bench: (cell phone pics)
    Senior Member hotbo's Avatar
    lake Ouachita AR
    you get my last pm today
    your makin me Jealous
    Mike (Steel is doing Dads heads and intake also)
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Yeah...thought I wrote you back, just must have forgotten to push the send button. Dang fancy contraptions, anyway...
    Don't be jealous.
    Derby, Kansas
    continued:
    You guys running that stock 4150 top?
    BTW the manifold work looks nice Scott.
    It's not stock any more.
    Thanks Loren.
    Somewhere between Paso & L.A.
    Thanks Loren.
    thought for sure you was gonna offer to make another bad a-s billet one
    for him!
    p.s. hey steel, how did you come up with your end dimensions for the proper spacer thickness? I know that's the ticket for those rams to make
    'em more useable, remember seeing dyno testing, don't remember how
    to determine proper thickness- or is that "privledged information"
    Derby, Kansas
    Quote Originally Posted by Blownjet 468 View Post
    for him!
    Lol, I have one on the shelf if they want it. Trying to keep one in stock now.
    for him!
    Just part of an engine software that gives an "optimum" volume, but from what I read, there's also no real "general" formula. Some suggest a volume based on a percentage of the displacement, or 1.5 times one cylinder...stuff like that (with no consistensy what so ever), but the bottom line seems to be that almost any time you increase plenum volume, you will increase power across the board.
    Derby, Kansas
    Now what does that increased plenum volume do for throttle response and drivability? I assume as with most things engine it's a give and take. The larger the plenum the more overall power but with some sacrifice of throttle response, less plenum you may not see as much power but could possibly benefit from more response???
    member
    Nov 2008
    Thumbs up
    Very nice work, looks great!
    On a 540 with a pair of 4150's I think the throttle response will be there. Probably not so much with a pair of 1050's or a smaller engine. It's easy enough to test with/without the spacer.
    Thanks.
    Nice Scott.
    Did you by chance run any of the math on the intake runner length to see what pluse wave you're catching for the rpm it's goin to run?
    S CP
