454 bbc build
Page 1 of 12 1 2 3 4 11 ... LastLast
Results 1 to 14 of 160
454 bbc build
    May 2010
    Discovery Bay, CA
    Default 454 bbc build
    OK here it is
    Ok heres my build that cost me about $3,500 parts and machine work only
    454 4 bolt Hi Perf block bored .060 over (4.31)
    Hi Perf 990 rectangular port heads pocket ported and polished chambers 118 volume
    stock rods and crank with ARP bolts (balanced and blue printed)
    Keith Black Hyper pistons part#257 25.5cc domes (10.5 cr)
    Comp Cams Xtreme Marine xm286hr grind hydraulic roller cam (566 lift 296/302 duration) 112 lobe seperation
    Comp Cam roller lifters
    Comp Cam one piece push rods
    Comp Cams Ultra Pro roller rockers
    Comp Cams Springs and retainers
    Cloyes Double roller timing chain
    Cloyes Timing cover with cam button
    Melling high volume high pressure oil pump
    14 quart Dooley oil pan
    Edelbrock Victor jr 454r manifold
    850 Double pumper holley
    per comp cams Cam Quest 6 specs program should produce 647 hp @ 6,000 rpm
    615 ft lbs torque @ 5,000rpm ?
    Any input to what to exspect or what impeller I should run in a Berkley JC? I am currently running an A impeller
    Break Out AnotherThousand
    Redding, CA
    Mines real close to that build.
    Same exact cam.
    I have Brodix 280cc runner square port heads, TR with 660's, but a little less compression than yours.
    Turns an A to 5800. (625 HP) Was a JC, but put a JG bowl with droop and place.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Somewhere between Paso & L.A.
    my experience with that program is they are very "generous" with their HP
    figures I look at that program as a CC "sales tool" some are close, others are a little far fetched-
    Ah come on! You really think CC would do that Nothing about that build screams 650 HP.
    Tri-Cities, TN
    Do yourself a favor and get yourself some Morel hyd roller lifters.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    May 2010
    Discovery Bay, CA
    [QUOTE=gn7;1293611]Ah come on! You really think CC would do that Nothing about that build screams 650 HP.[/QUOTE
    Thats what I thought in your honest opinion what do you think HP and TQ would be?
    Cstaub might be able to give you a harder number. But I would think 575-600 would be a more honest guesstimate.
    well if you want to see somthing funny, punch in your same specs in the
    compcams "camseller" program, but drop your compression ratio about 2
    points, and then look at the HP, now tell me it's believeable of course
    I forgot you CAN make that kind of power, but ONLY if it's a stock surburban short block
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    I agree
    [/SIGPIC]
    ANYTHING BUT COMP CAMS I don't like their stuff!!!
    Quote Originally Posted by Blownjet 468 View Post
    of course
    Makes you Mmmmm, I wonder, just a cam and manifold
    LINK: 600HP the easy way
    cfm
    cfm is offline
    Quote Originally Posted by orange bahner View Post
    I'm assuming the XM296HR ?
    With the following specs:
    Brand COMP Cams
    Manufacturer's Part Number 11-456-8
    Part Type Camshafts
    Product Line COMP Cams Xtreme Marine Camshafts
    Summit Racing Part Number CCA-11-456-8
    UPC 36584038542
    Cam Style Hydraulic roller tappet
    Basic Operating RPM Range 2,800-6,200
    Intake Duration at 050 inch Lift 242
    Exhaust Duration at 050 inch Lift 248
    Duration at 050 inch Lift 242 int./248 exh.
    Advertised Intake Duration 296
    Advertised Exhaust Duration 302
    Advertised Duration 296 int./302 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio 0.566 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio 0.566 in.
    Valve Lift with Factory Rocker Arm Ratio 0.566 int./0.566 exh.
    Lobe Separation (degrees) 112
    Computer-Controlled Compatible No
    Grind Number CB XM 296HR-12
    Valve Springs Required Yes
    Quantity Sold individually.
    Notes Designed for marine use. Requires thrust button and wear plate.
    Yeah, I kind of wondered about the XM 286 thing myself. Comp Cams part numbers usually coincide with the advertised duration of the cam.
    not to get off topic, but does Morel make lifters for lunati and howards?
