What cam????
Results 1 to 14 of 27
What cam????
    Under yo mommas bed jangles's Avatar
    Marana, Az
    Default What cam????
    Okay, so now that I switched completely from outboards to a vdrive I need some engine building tips.
    I have a 468 with 990 heads and a single 850 holley and a very mellow cam. What I am thinking of doing is switching to a tunnel with 2 750 4150s , adding nitrous and a nice cam. Problem is I don't know anything about cams and what will work with these heads. I am not going to do any work to the heads at this time or to the lower end . We shall see if it lets loose or not. Can I get an AMEN?? Well, a cam reccomendation will do it. I really can't afford to keep buying crap I can't use so someone please help an old man out.
    Thax
    jangles
    "Thanking Obama for killing Bin Laden is like thanking Ronald McDonald for the hamburger.
    Thank the SEALS NOT the CLOWN.
    Official Member IttyBittyTittyCommitee
    http://newsbusters.org/
    I would use something in the .630 lift range with a duration of 260 or so @ .050 with a 110 or 112 center on the lobes.
    Derby, Kansas
    Quote Originally Posted by jangles View Post
    Thax
    jangles
    Well what size is the cam in it now, do you like it?
    What rpm do you want to spin, what rpm range are you looking for?
    What compression, gear, prop are you running?
    How much nitrous do you plan on running and how often will you use the nitrous?
    What type of cam, flat, roller, hyd, solid?
    Marana, Az
    Loren, my answer to all of that is I don't know. Seriously, I haven't had the boat in the water.
    If that's the case, any cam will do. Just pick the one at the bottom of the list and plug it in!!!
    Seriously, you might want to run the boat as is and see where you're at. Once you know where your at, it's easier to figure out where to go to get where you wanna be.
    Somewhere between Paso & L.A.
    X2-on the second comment, that is
    Marana, Az
    Naw, the thing is bone stock and it's out right now. Time to build a motor and I'll gear to it. Next...........
    what do you mean "bone stock"? if it has 990's on it, it's what, a "bone
    stock" LS-6/LS-7? That's a far cry from say a ''surburban short block"
    Menifee
    Thax
    jangles
    If you want a flat tappet dealio run the Isky Z-89. It will work perfect with those heads.....
    Almost the same specs as the Z-89 (with the exception of the lobe cntr)
    Quote Originally Posted by Blownjet 468 View Post
    Those "stock heads" don't give a shit what shortblock is under them and neither will that cam. The bottom end is just along for the ride. The small cam with the lousy design of the 990 head will work perfect from an 8:1 stocker to a 12:1 LS7.
    In a decent set up true flatty that combo should run a tic over 90. Faster of course in a Runner bottom. Ask me how I know.....
    Keith...
    Marana, Az
    Thank you , I need all the help I can get. This is going in my Sanger hydro, does that change anything concerning cam, etc?
    Happy Turkey Day!!!!!!!!!!!!
    Derby, Kansas
    If you can run a cranking compression or tell me if it's domed or flat top pistons I can tell you what cams I've had and liked.
    I sort of agree with quickjet but I wouldn't cam my boat the same from 8:1 to 12:1, true you can drop the gear to let it spin but there are some drawbacks.
    My favorite low compression (9:1) cam with my 990s was 258/[email protected]" on a 110lsa installed on a 108, lift was .588"/.601", not very wild but easy on parts and would turn 7k.
    My current cam is being run with a true 12.5:1 and the 990 heads is 268/[email protected]" on a 110lsa installed on a 109, lift is .643"/.633" this one runs harder but is about my limit for a dual purpose deal trying to pull skiers.
    OK, from MY personal experience - I have run THIS CROWER SOLID in 2
    different engines- 1 was a 9.5 to 1 motor, the other was a 12to 1,
    I had the cam for the 9.5to 1 motor ground on a 110*lsa, while the 12 to1
    motor was ground to catolog spec on a 107* lsa- both motors ran extremely well- the 12 to1 engine was in a v drive w/ported 990's, a HOGAN'S T-RAM w/2-750's and I believe 19 gears- the 9.5 to 1 motor
    had big valve 049's with the "OVAL PORT VICTOR RAM" (pro-street ram)
    with 2-650dp's in an "A" impeller 19' jet
    spec's are as follows: crower # 01355
    v-drive jet
    292/300adv. 254/[email protected] .050 595/622lift 107llsa 110lsa
    funny how this is "oh so close" to Carnival Rides pick! somthing to ponder
    isn't it?
    Default From past experience . . .
    FWIW . . . , This is what I would do for my jetboat guys that wanted something to run good and sound good, but did not want to do a lot to the rest of the motor, most often bone stock.
    There were some cams that Elgin used to make, but a lot of mfgs were making the exact same grind and marketing them under different private labels and names. May have also been a Melling product.
    Conventional Hydraulic Lifters, 230/230 @ .050, .544/.544, ground with a 109 LC. Since these were going into a jetboat motor and would never see 6,000, I would put them in at 9 or 10 degrees advanced (Intake CL end up sitting at 99 or 100).
    Did everything they expected, sounded good, and picked up about 15% - 20% in fuel economy from their stock setup and used regular fuel. You will hear lots of guys that won't agree and think this is too much advance, but the results were solid and troublefree (if they used the right oil and kept it free of water).
    Worked very well for me and my customers, but, you will most likely crispy critter that deal if you use the nitrous.
    Take care, K
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Those "stock heads" don't give a shit what shortblock is under them and neither will that cam. The bottom end is just along for the ride. The small cam with the lousy design of the 990 head will work perfect from an 8:1 stocker to a 12:1 LS7. In a decent set up true flatty that combo should run a tic over 90. Faster of course in a Runner bottom. Ask me how I know.....
    Thats probably a good bet. Im at 11:1 CR, TR with 660's running the Isky Z-97 which is .665 int/.654 exh with a 274/286 duration @ 110 degree lobe ctr. with 990 ported heads. Isky has all the springs, rockers and everything together in kit package.
    http://www.iskycams.com/onlinecatalog.html
