Heads for TNYoungblood
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
    Default Heads for TNYoungblood
    Finally got some pics to put up for TNYoungblood's 540 build.
    Basically start with this:
    Vallve seats bored to the proper ID and the bowls roughed in:
    Once the bowls are done, I start on the ports. Sometimes I have both heads on the bench making sure they're as close as possible to being the same. Measure and grind...measure and grind...
    Doing some area correction at the short turn. It's hard to tell, but I removed .100" from the roof of the port and around the guide boss, and about .030 from each side. Thhis also gives me a chance to contour the guide boss a little.
    Before:
    Roughed in:
    I pretty much finish the ports, then I do the valve job and chambers get roughed in:
    Finished ports:
    Finished chambers and final valve job:
    And there you have it. Still waiting on springs and retainers to final assemble.
    Right hand intake port only ended up at 316cc, chambers at 118-118.2 .
    Final flow numbers:
    Int. good/bad ex
    .2 155/153 117
    .3 221/221 158
    .4 283/279 198
    .5 335/321 232
    .6 369/347 258
    .7 386/367 279
    .8 379/377 291
    Menifee
    Looking great Scott!!!
    What cam yah gonna run?
    Keith...
    Somewhere between Paso & L.A.
    NOW THAT'S THE WORK OF A "TRUE PROFESSIONAL"
    NICE JOB INDEED!
    One of Chris' solid rollers. I think he used the red and green dart for this one.
    Quote Originally Posted by Blownjet 468 View Post
    NICE JOB INDEED!
    Thanks bud.
    Menifee
    Cool...I like the "Science" that is involved....
    Keith...
    Nice workmanship and attention to detail! The castings look very good quality as well.
    Mar 2010
    Clarksville, TN
    Looks AWSOME Scott .. I'm glad you were able to take ur time on these, they turned out real nice .. Looks great and i'm sure there gonna run as good as they look .. We'll wake up the neighbors with this one ...
    Cant wait to get them under the tree !!!!
    Santa Clause is coming to Town
    Default heads
    What brand of heads are they
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by matt wheeler View Post
    There a set of Canfields
    Shame ot bolt 'em to an engine and get 'em all dirty, but they WILL make some beautiful noise.
    Quote Originally Posted by downsouth View Post
    Thanks. Canfields are definitely some good castings. Hopefully the new version will follow in suite.
    Nice work Scott.
    Piston to be used and what's the target compression ?
    S CP
