Cubic Inch Chart : BBF sizes
Results 1 to 14 of 24
    Default Cubic Inch Chart : BBF sizes
    I did one of these before, I just got around to adding a few more lines to fill in some gaps. It might come in handy for a some of the Ford guys :
    S CP
    Its' real easy to figure c.u. --- 8 x .7854 x Bore x bore x stroke = cubic inches. It doesn't take a chart! M
    Cantard 71hallett's Avatar
    snow bank
    Its faster to read the chart than to find a calculator that works.
    Senior Member 78COLE's Avatar
    Greenville SC
    Had one for Chevy but thanks for the Ford info... never know when might need it.
    Ole guy, the charts are nice because it allows you to see all the "somewhat" standard combos at a glance. Ever notice the number of combos with the same CID. The formula is great for determining a specific combo size. But when you looking for different combos of the same size, it makes it a little easier. Someday I may post all the possible CIDs with 2 deck chevy deck heights 3 cranks, and 3 rod lengths, and 3 piston CHs. Its pretty amzing the different engines sizes and compression combos. Its a tad more than 3 combos. If your stuck thinking a 470 is automatically a 4.320 X 4.00, then the chart is of no use to you.
    I just use the chart this weekend to determine all the possible combos that are available for a 514. Long story why I needed this info, but there are five on that chart alone. Add in all the combos that are between 510 and 515, and it gets even bigger.
    Some people, Ole Guy, actually use charts like this to help decide possible combos. People who think outside the box.
    Some people use dyno's too
    Quote Originally Posted by 78COLE View Post
    I forgot the stock 427 Ford size of 4.23. I might add a few more. There are a few odd-ball sizes on the chart but it's now possible to have a pistons made in any size and ring packs can be file fitted to fit damn near any thing.
    S CP
    And don't forget the 4.320 bore that is very common with the BBC boys now, and always was common with the MoPar geeks
    Thanks...you have a couple more common sizes that might be worth adding ?
    S CP
    Senior Member bp298's Avatar
    LHC
    maybe that's why he included the same formula at the bottom of the chart
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    I don't know if that would work for you up there in the great white north, you guys do every thing screwy up there. Besides, the batteries are probably frozen in the calculator.
    You mean that teeny tiny little print at the bottom? You expected him to read that? He was too busy trashing the post before he got that far.
    Quote Originally Posted by jorndy View Post
    They have batteries there? And they work in sub-zero weather?
    Who knew. Paul has no need for batteries. He is way more hi tech than that.
    LHC
    font size on the chart looks the same as the font size in the post... but i guess if ya didn't look, you wouldn't see it...
    Oh Mark is harmless he just feels he owes me a few
    GN, I'm like you I need a chart in front of me so I can see the possible combination, but then again I need a dyno to tune an engine too.
    I'll add those other combo's to the chart later and re-post.
    S CP
