piston cleaning
piston cleaning
    Feb 2010
    Default piston cleaning
    who has the best doityourself way to get some carbon off some used pistions, can you soak them in a miricle cleaner like clr or what.
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Water. Its that simple. Over nite or longer. Soak em, scub em with a scotch brite, throw back in, repeat as needed. Don't be so dumb as to leave the pins or locks in.
    Feb 2010
    its just the top so i can put them in a cookie sheet. skirts are clean.
    Well, there ya go But watch the rings And allow the water to get under them. Flat tops on a cookie sheet won't get it done.
