Mopar id
Results 1 to 14 of 18
Mopar id
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    Default Mopar id
    Anyone know where I can ID a MOPAR oem tunnel ram?
    Part# P4532067 on top
    On bottom P4532277-2
    "Pot had helped, and booze; maybe a little blow when you could afford it. Not smack, though" President Barack Obama.
    Liberals just chose to ignore relevant information about the world they live in, and then call themselves sophisticated for having chosen to be more stupid than God made them.
    CIUDAD MEXICO NORTE
    Yes. with MOPAR and the part # number in the middle and a second part number on the bottom.
    I think it's for a 360 but not sure.
    The one in the pic is for a 440. The problem I am running into is the second number you gave doesn't jive with anything. And the top number fits multiple MoPar Performance lowers. It could be for anything from a 340/360 to a W2, 383, or 440.
    CIUDAD MEXICO NORTE
    The intake is two piece the second number is on the very bottom.
    There's also a small B B in upper case below the number.
    Big Block?
    Most likely B Block, as opposed to RB block, or LA block. The B block is 383/400, 9.980 center of crank to deck. The RB blocks were 413/426/440, 10.725 center of crank to deck.
    CIUDAD MEXICO NORTE
    Can you give me any measuements off of the 440 intake in the pic?
    I don't have the manifold I posted the pic of. The easiest way to tell which is which is by the width across from head to head flanges. I will see what I can find.
    CIUDAD MEXICO NORTE
    Thanks!
    I gues I need to make a foray into a MOPAR site.
    Just Me snoc653's Avatar
    Eastern Iowa
    If you haven't figured it out by mid Jan., I'll measure my intake back home. Mine is a Weiand so it won't match your part numbers but it is for a RB block and I have the figures for the B block there too.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by 500BBC View Post
    Big Block?
    If the "BB" is staggered high-low (in such a way that the upper B is adjacent to the lower B in a diagonal fashion), then that is the logo for the Buddy Bar casting foundry in Los Angeles.
    LO
    High Flow Dynamics
    California
    Got a 440 we're rebuilding in the shop, from the corners where the heads meet the block across the china wall its approximately 8.750" and the actual width of the intake in that area is closer to 9"....if that helps
    Quote Originally Posted by LakesOnly View Post
    LO
    Dang LO, that never even crossed my mind. And it should have because I have seen that way too many times. Only, when I see it, the furthest thing from my mind is big block, or "B" block.
    Thats all you need right there 500BBC. If its close to that, its a 413/426/440. If it somewhat narrower, it a 383/400
