Dry Sump Oil Pump, Pro's & Con's
Results 1 to 14 of 34
    Lake Havasu
    Default Dry Sump Oil Pump, Pro's & Con's
    I use low tension rings and a vacuum pump on a NA motor. I have heard people say that a dry sump oil pump creates vacuum as well. So I'm considering switching to a dry sump system and wondering what the pro's and con's are, besides cost and "clutter".
  2. #2
    Somewhere between Paso & L.A.
    the only con's to a dry sump IMHO, is what you already posted!(and of course, having
    to send all the new fittings, brackets, pullies, etc, back to have them annodized gold!)
    love your setup, it's over the top!
  3. #3
    Mohave Valley/Quartzsite
    I agree with Blownjet.. I can't think of any cons other than cost, clutter and weight..
    Pros: Less windage in the motor, Constant oil feed regardless of acceleration, deceleration, hard turning, etc.. Provides some more vacuum on the motor..
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
  4. #4
    waterloo
    Looks cool! Big pro.
    Wags
  5. #5
    Nov 2008
    Orangevale CA
    Quote Originally Posted by stix818 View Post
    X-2 on the constant oil feed . I have a Barnes pump , with all gears(on the pressure and scavenging side), on my blown motor it spit a valve cover plug (rubber push in ) into the lake . JMO if you wanted a lot of vacuum I would get a pump with rotors on the scavenging side . ... E
  6. #6
    Lake Havasu
    Quote Originally Posted by Blownjet 468 View Post
    Thanks for the compliment. Making them purdy is easy. Making them work, thats another thing....
  7. #7
    Nov 2008
    Orangevale CA
    BTW -- I was going after oil pressure all the time (when slowing down), Not vacuum, ...E
  8. #8
    The only other con besides the ones you mentioned is weight. But the pros out weight the cons. Besides the ALMOST guaranteed oil supply, it will free up some hP. Partly due to the vacuum, but you already are doing that. But from less oil flying around the crank. Can be as much as 50 HP on a BBC depending on the stoke and the current pan. On a BBF its alittle less.
  9. #9
    Peoria, AZ
    Some of the other cons are cracking fittings and having the inside of the suction lines collapse. I have only seen a line collapse internally once, but it was on the line from the supply line therefore not allowing oil to the motor. I have seen fittings crack a handful of times. Other than that it is the way to go. If I saw it as that bad of an option than I would not be planning two dry sump motors myself.
    Paul
  10. #10
    There is no doubt that system failure is an issue. Just way more pieces involved. Belts breaking, getting pitched, pulley shearing keys etc. I have seen most them. But it is still the best "racing" oil system.
  11. #11
    Peoria, AZ
    Yep. I just wanted to make sure it was clear for those who have not yet played with them just because it says dry sump does not mean it can't have a failure.
    Paul
  12. #12
    Lake Havasu
    Okay, next question. How many stages do I need and where to scavage from? I am using a Dart aluminum race block, if that matters.
  13. #13
    Senior Member badbug3's Avatar
    what is your application for the dry sump?
  14. #14
    SoCal
    Make sure you support the lines and dont let them flop around. That will lead to broken fittings and line abrasion. They will not pull as much vacum as a vacum pump ( the ones Ive played with) so I dont know how much your pulling now. Did you ring the motor with the intention of a vac pump???
    Other than than whats allready been said, really no cons other than cost and room.
