Alittle miss at idle
Results 1 to 12 of 12
    Senior Member cave's Avatar
    Mesa, AZ
    Default Alittle miss at idle
    I've had this miss in the engine since I pick it up in February. It runs fine but has a miss while I'm cruising. Engine is a Gen VI BBC 502 bored .30 over with a 850 Holly double pumper carb. New MSD 6AL with a 7K Rev limiter chip. New MSD Blaster Coil New MSD Dist Trigger. New MSD Dist Cap.
    Timing is set at 32° @ 3000rpm. I've cleaned the carb with carb cleaner.
    It almost sounds like the carb suck a gulp of air right before it has the miss.
    Many thanks up front.
    Takin it home
    Newton Ks.
    A miss at idle or a miss at moderate RPM "while cruising"?
    H.L. Mencken
    Mesa, AZ
    Its at idle. No pedal at all. The RPM at Idle is 1100. Oh I also replaced the dist rotar.
    Takin it home
    Cantard 71hallett's Avatar
    snow bank
    Float level to high or power valve dried up or leaking? That noise is usualy a chunk of fuel hitting the thottle plate.
    Mesa, AZ
    I'll check that out.
    Takin it home
    May be some water in the fuel
    Mesa, AZ
    Maybe but I got 2 water separators. They may need to be changed.
    Takin it home
    The one and only time I bought gas on the water, I had problems, kept getting worse and worse. fought it for almost a full season, water seperaters did'nt even do the job. found water dropplets in the carb bowls, led me to the one tank, I had fuel delivery issues with. Ended up draining both tanks, to cure the problem.
    snow bank
    How did you make out?
    Mesa, AZ
    Works picked up so I'll have to make time on Friday. I bought a few power jets and I drained the water separators
    Takin it home
    snow bank
    Cool, hope it works out for you. Nothing like some weekend agrivation. lol
    Hey cave man, If you say you hear something in the carb and then a miss you might want to check valve adjustment. Also power valves could be the culprit. Personaly I would loose the power valves on a marine application,go to plugs and step on the jet size by 1 or 2 points. M
